Author Topic: help- stripped threads on stud on starter  (Read 909 times)
Offline 70 RAG TOP
« on: July 07, 2011 - 11:31:01 PM »
I just purchased a rebuilt starter on the internet and I have already screwed up!  It is a mini starter, not the oem style starter.  I failed to realize that it is probably a nippendenso, therefore most likely has metric threads.  I used a standard nut on the small stud( next to the larger "battery power" stud) and ended up stripping the threads.  My question is? Can a starter/alternator rebuilder replace just the affected stud, by soldering in a new one?
thanks
Offline Strawdawg
    • Vortex Buicks
Re: help- stripped threads on stud on starter
« Reply #1 on: July 07, 2011 - 11:39:16 PM »
they used to be available so I suspect a proper electrical shop will have them
Offline Grec
« Reply #2 on: July 08, 2011 - 06:49:20 PM »
Coundn't you just re-tap it to fit the standard nut you tried in the first place? Or is there not enough stud left... ?
1973 Challenger Rallye
- 440 Six Pack
- A833 4 Speed, 18 Spline
- FE5 Rallye Red on Black
Offline Matt70
« Reply #3 on: July 08, 2011 - 07:32:31 PM »
 :iagree: I'd try that first, or maybe try and clean up the metric ones
People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf.
George Orwell
Offline 70 RAG TOP
« Reply #4 on: July 10, 2011 - 02:03:29 AM »
Thanks for your help guys .  I thought about going the retapping route, but the stud was so small and short that the die barely started on the threads before it bottomed out on the starter.  I actually found a local starter rebuilder that replaced the stud with a new one for only about $15.  If anybody ever has this problem, that is the best way to go.
Thanks again everyone.
