Author Topic: How much Clearance should you have between Hood and Air Cleaner???  (Read 623 times)
How much Clearance should you have between an RT Hood (Underside surface and cross bar) and a Chrome 14" Air Cleaner? Allowing for shake, rattle and roll of the engine and so nothing breaks if zero clearance.
I'm thinking of going to a higher air cleaner (height) maybe a Wix Filter (Paper) if the clearance allows.
Have a 2.25" x 14" Round K&N Filter, Holley Carb, Mopar Aluminum Intake Manifold on a 440 which is probably higher than a stock manifold.
What's a safe quick and dirty number for clearance?
Thanks.
« Last Edit: July 08, 2011 - 02:06:15 AM by 1970 RT Challenger 1970 »
Offline LAA66
Re: How much Clearance should you have between Hood and Air Cleaner???
« Reply #1 on: July 08, 2011 - 10:07:19 AM »
 Mine is about 3/8" although there is a solid motor mount on the driverside. Use some putty on top of the lid and carefully close the hood to check clearance. I think the hood cross support was the critical tolerance point on my 340.
