Author Topic: 1972 Dodge Challenger 'GT' project  (Read 47689 times)
Offline airfueleddie
Re: 1972 Dodge Challenger 'GT' project
« Reply #135 on: August 05, 2014 - 02:05:55 PM »
Thanks for the idea AL Auto,,can I ask,,did the top of the front end ever rub against the lift 'arm' it looks like it would clear just fine! What did you attach the lift chain or boom/arm  to?  Thanks
« Reply #136 on: August 05, 2014 - 02:32:03 PM »
Your strut rod washers are on backwards.  That's not how the factory did it.  There were some Moog washers that had wording on them that said to install them that way.  I don't know why.
« Reply #137 on: August 05, 2014 - 03:32:46 PM »
Thanks Burdar,,but the bushing is different than the factory style. It has a radius on it. The way I have it now conforms more to that 'radius' than the other way? Thanks
Offline roadman5312
« Reply #138 on: August 05, 2014 - 03:43:51 PM »
Just looked thru this entire thread, very nice build. Going to use a few ideas I saw here on the Hemi build.   :cheers:   :popcorn:
« Reply #139 on: August 05, 2014 - 04:03:28 PM »
Quote
Do you have a picture of it?  I'd like to see it.
Offline anlauto
« Reply #140 on: August 05, 2014 - 04:50:05 PM »
There's two hole in front of the forward K Frame bolt holes. I just hook 2ton tie down straps there....everything clears no problem
« Reply #141 on: August 05, 2014 - 06:55:09 PM »
Thanks ANL Auto! I might just do that!  Burdar,,,,I will try and get you a pic of the original style bushing versus  the black Poly bushings I got from Firm Feel OK
« Reply #142 on: August 05, 2014 - 07:09:47 PM »
Here is a pic,,,Burdar. I went ahead and swapped them round the other way. I really don't think it will matter,,,but  I went ahead and did it.  Thank You Burdar!!!! :thumbsup:
« Last Edit: August 05, 2014 - 07:14:41 PM by airfueleddie »
« Reply #143 on: August 05, 2014 - 07:13:04 PM »
#2
« Reply #144 on: August 14, 2014 - 10:17:52 PM »
Trick Serpentine system installed
« Reply #145 on: August 14, 2014 - 10:20:20 PM »
Sat,,is the "Body drop day"  I'll post pics when the powertrain is installed
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #146 on: August 14, 2014 - 11:36:27 PM »
 :ylsuper:  Looking SWEET!
Can't wait to see it in the car!
« Reply #147 on: August 15, 2014 - 12:54:24 AM »
Thanks Dfrazz,,cant wait myself! LOL :2thumbs:
« Reply #148 on: August 15, 2014 - 01:07:47 AM »
Forgot to mention,,The Serpentine system can be purchased at www.sdconcepts.com Jerry is a great guy to deal with,,backs his products, and is an excellent Machinist/Designer. There a couple parts you can source like the Dodge Ram Truck 93-97 Denso style Alternator,(I bought a Rock Auto 90 AMP TYI unit,,all new parts with Power rating dyno sheet), Jeep Grand Cher. V-8 Power Steering Pump,(also a Rock Auto Purchase), the Pump Pulley is a Dorman unit,,plastic press on,,cake with the right tool,(harbor freight,,15 bucks), of course you can get those parts from a junkyard as well. The water pump pulley is a billet piece from Jerry or from a Ram truck 93-97 (other years may fit,,I just used those years and MoPar made some changes after 99 I think). The Dodge Ram Truck crank pulley I had in my parts stash,,93-97,,I think after 97? they went with a integrated pulley/damper,,Idler pulley is a Gates, Tensioner from a Chevy Van. Jerry will give you a shopping list or some parts he makes,(pulleys). So you have options to lower the cost somewhat. I am driving this beast cross country and into Canada so I wanted to build extra dependability into this project and ease of maintenance/breakdown time ect
« Reply #149 on: August 17, 2014 - 01:04:53 AM »
It's 'Home' ,,whew,,everything cleared just fine! I was going to do what AL auto suggested,,but was afraid the dolly wouldn't clear the 'legs' on the picker.
