Author Topic: 1972 Dodge Challenger 'GT' project  (Read 47712 times)
Re: 1972 Dodge Challenger 'GT' project
« Reply #75 on: August 03, 2012 - 02:54:32 PM »
I looked around forever for a silicone rubber pan gasket that had the steel inserts in it to prevent over tightening too but couldn't find one( dime a dozen for SBC) , so I settled for Milodon pan gaskets, I needed 2 as I also installed the Milodon windage tray.
I hear ya on the broke aspect!  :grinyes: I've dropped 17k into my new drivetrain.... motor, tranny, new dana.
I sure hope the wife never see's this!  :eek4:  :lol:  I sold 2 other cars to finance it, sure feels funny looking down at a pile of parts and thinking "this is my 455 Buick and 55 Chevy?"   :eek7:
Offline airfueleddie
« Reply #76 on: August 05, 2012 - 10:50:04 AM »
So Brad, you had to sell your Chevy too? here is my all original 1962 Biscayne, ordered by my Family back in late 1961. I had to let her go to a guy that owned 3 of em. This is an 62k mile car with no rust, 99% original. I was gonna build it with a straight axle, injected hemi, Dana. Piss of the gm gassers with a MoPar powered brick! LOL
« Reply #77 on: August 05, 2012 - 10:55:06 AM »
OK, I got the Milodon Pro-Touring Pan, Barton fel-Pro gasket, 1/2 pickup. Now I have to remove the 3 &4 main studs to rempove the old pick-up then install the Milodon piece.(The main studs prevent the last few threads).
« Reply #78 on: August 05, 2012 - 12:14:09 PM »
Wow it is in great shape!
« Reply #79 on: August 05, 2012 - 12:32:17 PM »
Thanks Brad, even though I am 100% MoPar, I remember my Pops and his sister,(My Aunt), driving us kids in the mid 60's down the country roads. It hurt a bunch to let that car go. My Dad is gone but my Aunt is still alive, she's 94. She wasnt happy to hear it go, but I had to..no where to keep it out of the weather. It went to a good home. It had 62K miles on it. Never driven in the rain or snow.
Offline 440STRKR
« Reply #80 on: August 12, 2012 - 09:44:56 AM »
Sweeeet car!
« Reply #81 on: August 20, 2012 - 12:32:56 PM »
Thanks 440STRKR!!  I got the Milodon Pro-Touring Oil pan on but I couldnt use the windage tray. Simply no clearance with one. Here is a pic.
« Reply #82 on: August 20, 2012 - 12:37:36 PM »
pan is on there!  I now have to figure out if the TTI or Dougs headers in 1 7/8 or possibly 2" will clear the oil temp. sending unit?  If it doesnt I'll plug it and move on. Anyone know offhand? Thanks guys,,,,Eddie
« Reply #83 on: August 20, 2012 - 02:12:41 PM »
FYI test fit it in your k-frame. I had to cut the motor mount gussets in 2 places to fit that pan. No biggie, just good to know before you install.
« Reply #84 on: August 21, 2012 - 12:48:34 AM »
Thanks a bunch Brad! I am fortunate to have this info!!!  Oh yeah, you are correct about the skid plate sway bar issue. I might have to wuss out and go with a 1" or a bit larger when it comes time to order the bar from Dick Ross, OR I may just cut that plate off and get the right bar for my chassis/suspension,, Ive come this far hate to 1/2 Azz it and I can cut/ weld it back on no problem.
« Reply #85 on: August 21, 2012 - 12:57:15 AM »
I go with a 1 1/4" hollow sway bar from Hotchkis or PST?  ... but then again I'm a bit of a weight freak? :grinyes:
« Reply #86 on: October 01, 2012 - 01:48:52 PM »
Stripping the floor pans. The previous owner must have used the lowest cost paint, it simply flaked off with my finger nails! I am going to either use "lizard skin' coating or Rust Bullet and Dyna mat  either way I want the NutBucket to be protected against corrosion because they use a liberal amount of salt and other liquid types of metal killers on our roads anytime it falls below 35 degrees! I also have to cut out the transmission tunnel when the LGT SS 700 5-speeder becomes available from Keisler.
« Reply #87 on: November 10, 2012 - 01:32:16 PM »
Interior floor pans done, inside and bottom side. I used rust bullet then gloss white, the underside will recieve a final thick coat of asphaltic tar based undercoating. No more work till spring. Out of money
Offline DAYLEY/CHALLENGER
« Reply #88 on: November 10, 2012 - 07:09:49 PM »
So clean you can eat off of the floor.............Nice work.........Looking forward to updates.............David
Dave or David
« Reply #89 on: November 11, 2012 - 08:45:33 AM »
probably too late now but what about using a crank scraper at least inside the pan ?
