Author Topic: What to use to clean up dash wiring  (Read 1272 times)
Offline Chlngrcrzy
« on: July 13, 2011 - 09:18:32 PM »
Any ideas of what to use to clean up the dash wiring harness with?  I have a couple corroded spots on the wiring also that need to be repaired. Their just spots and not corroded through. How would you fix these?
Offline Strawdawg
    • Vortex Buicks
Re: What to use to clean up dash wiring
« Reply #1 on: July 14, 2011 - 09:14:26 AM »
You might try something like WD40 on a shop rag and wipe it down/off.  If any parts need retaping, you can use the tape sold for harnesses rather than electrical tape.
Or, Armorall cleaner, or such
« Reply #2 on: July 14, 2011 - 12:59:17 PM »
I've used soap/water with good results.  The more stuborn spots I cleaned up with WD-40 and/or mineral spirits.  Corroded connectors can be soaked in vinegar.  Once they are free from corrosion, you can buff them with 0000 steel wool.  Use compressed air to dry.
Offline Chlngrcrzy
« Reply #3 on: July 14, 2011 - 01:15:39 PM »
Awesome. Thanks guys for the info.     :2thumbs:
Offline Sean
    • My Cuda Restore
« Reply #4 on: July 15, 2011 - 06:14:29 PM »
Believe it or not, you can use molases to clean parts.  A buddy of mine soaked rusty and greasy parts in molases diluted with water (10:1 ratio) and they came out great.  The parts that he showed me was a steel turnsignal bucket with pigtail and a hood latch off a Chevelle.  All the rust and corrosion was gone after soaking for about 2 weeks.  He said he used industrial molases - not what you'd put on your pancakes.  The connections and wires on the pigtail looked brand new too.  After he pulled them out of the molases, all he did was hose them off with water and then he was going to dip the metal parts in a chemical (can't remember what) to prevent the rust from returning.  One draw back is that it stinks to high hell!!!  Not something you want to do IN the house!!!
Sean
Offline rallye73
  • Model cars for the big boys!!
« Reply #5 on: July 18, 2011 - 01:02:36 AM »
I put mine in the dishwasher. Got the idea from a friend who works on old cars. It worked really good!!
John Moorman
1971 Challenger R/T 383 4 speed (waiting it's turn)
1973 Challenger Rallye 340 4 speed (undergoing full resto)
2003 Dodge SRT-4 Stage 3 turbo daily driver-been as fast as 11.97et
1995 Dodge Neon Sport Coupe DOHC 5 speed Nitro-yellow-green (one of 527 built)
Offline dougs bs23
« Reply #6 on: July 26, 2011 - 11:31:23 AM »
dishwasher  :22yikes:  im sure the mrs was pleased with that.
