Lunati VooDoo XX302 grind for small blocks
Chryco,
Upgrading my 318 to 302 heads 1.88s and 1.60s...
Current stats (you critiqued my cam choice so now is your chance to proove your point Chryco)
318ci w/stock short block and heads
Comp Cams XE256H Duration 256/268 Lift447/455
Edelbrock Performer Intake
Chrysler Electronic Ignition
Road Demon 625cfm Vac Sec Carb.
So you recomended a look at the Voodoo's, but then this guy 6Paktogo you were a little more agressive I think with the 302 grind (which I'm not seeing as a VooDoo, but a Streetmaster)
Lunati outlines it as:
Hydraulic Flat Tappet. Good cam for Pro Street applications with 340-360 c.i. motors. Needs
2500-3000 RPM stall converter, headers, 10:1 com- pression and 3.50+ gearing. Rough idle.
•Advertised Duration (Int/Exh): 285/285
•Duration @ .050 (Int/Exh): 235/235
•Gross Valve Lift (Int/Exh): .507/.507
•LSA/ICL: 108
•Valve Lash (Int/Exh): Hyd/Hyd
•RPM Range: 2500-6200
•Includes: Cam Only
If I look at the VooDoos I see two options, the 702 as a bit more agressive...
Mid level performance street cam with excellent drivability. Works well with stock type exhaust manifolds and dual plane intake with mild 4 bbl carb.
Improved valve springs and roller rockers recommended.
•Advertised Duration (Int/Exh): 262/268
•Duration @ .050 (Int/Exh): 220/226
•Gross Valve Lift (Int/Exh): .475/.494
•LSA/ICL: 112/108
•RPM Range: 1400-5800
OR
on the milder side the 701:
Hydraulic Flat Tappet. Best mild performance cam. Works well in EFI applications with performance chip. Makes approximately 19" vacuum at idle. Great for performance marine and heavy towing applications. Great street rod cam. Slightly noticeable idle, works with stock converter, A/C, power brakes and stock springs in most cases.
•Advertised Duration (Int/Exh): 256/262
•Duration @ .050 (Int/Exh): 213/220
•Gross Valve Lift (Int/Exh): .454/.475
•LSA/ICL: 112/108
•RPM Range: 1000-5500
With the new heads I was leaning towards the 702.... as you recomended more lift, shorter duration... and a non-chevy grind...
I plan to run a TCI A904 with Sizzler Torque Converter and 3.55s behind it.
lead me to water so I may drink...
