318 cam question!
Author Topic: 318 cam question!  (Read 2819 times)
Offline Mr. 6pak2go
  • Restore it dont crush it!
318 cam question!
« on: July 14, 2011 - 08:56:00 AM »
Hey guys and gals iv got a 318 im building for my dart its basicly gonna be a stock build the heads and bottom end are stock im using a stock 340 intake a holley 4160 600 cfm carb heddman headers with a stock converter my question is what would be the best cam for this combo? and is 600 cfm gonna be to much for this combo im wanting to find a cam that will wake up the little 318 its just a street cruizer but i want to hold its own
My family, My cars, My guns three things il fight for!!
Offline burdar
Re: 318 cam question!
« Reply #1 on: July 14, 2011 - 01:06:16 PM »
I'm sure there are some more modern grinds that will give you more power then an old  purpleshaft.  However, I've heard that the stock 340 cam is a decent cam for a 318.  I've got one in the engine I'm putting in my Challenger.  I had it so I used it.
Offline OUTLAW
  • MASTER OF ALL THINGS MOPAR
  • I didn't say you can't RACE--I said you can't WIN
    • MOPAR-MADNESS  WEB/FORUM
« Reply #2 on: July 14, 2011 - 04:04:48 PM »
I also heard a 340 6 pak cam will wake up a 318
« Reply #3 on: July 14, 2011 - 11:05:10 PM »
Lunati VooDoo XX302 grind for small blocks
Offline LEMOOREACE
  • I was a llama, but I have since evolved.
« Reply #4 on: February 28, 2014 - 01:58:30 PM »
Chryco,
Upgrading my 318 to 302 heads 1.88s and 1.60s...
Current stats (you critiqued my cam choice so now is your chance to proove your point Chryco)
318ci w/stock short block and heads
Comp Cams XE256H Duration 256/268  Lift447/455
Edelbrock Performer Intake
Chrysler Electronic Ignition
Road Demon 625cfm Vac Sec Carb.
So you recomended a look at the Voodoo's, but then this guy 6Paktogo you were a little more agressive I think with the 302 grind (which I'm not seeing as a VooDoo, but a Streetmaster)
Lunati outlines it as:
Hydraulic Flat Tappet. Good cam for Pro Street applications with 340-360 c.i. motors. Needs 2500-3000 RPM stall converter, headers, 10:1 com- pression and 3.50+ gearing. Rough idle.
•Advertised Duration (Int/Exh): 285/285
•Duration @ .050 (Int/Exh): 235/235
•Gross Valve Lift (Int/Exh): .507/.507
•LSA/ICL: 108
•Valve Lash (Int/Exh): Hyd/Hyd
•RPM Range: 2500-6200
•Includes: Cam Only
If I look at the VooDoos I see two options, the 702 as a bit more agressive...
Mid level performance street cam with excellent drivability. Works well with stock type exhaust manifolds and dual plane intake with mild 4 bbl carb.
Improved valve springs and roller rockers recommended.
•Advertised Duration (Int/Exh): 262/268
•Duration @ .050 (Int/Exh): 220/226
•Gross Valve Lift (Int/Exh): .475/.494
•LSA/ICL: 112/108
•RPM Range: 1400-5800
OR
on the milder side the 701:
Hydraulic Flat Tappet. Best mild performance cam. Works well in EFI applications with performance chip. Makes approximately 19" vacuum at idle. Great for performance marine and heavy towing applications. Great street rod cam. Slightly noticeable idle, works with stock converter, A/C, power brakes and stock springs in most cases.
 •Advertised Duration (Int/Exh): 256/262
•Duration @ .050 (Int/Exh): 213/220
•Gross Valve Lift (Int/Exh): .454/.475
•LSA/ICL: 112/108
•RPM Range: 1000-5500
With the new heads I was leaning towards the 702....  as you recomended more lift, shorter duration...  and a non-chevy grind...
I plan to run a TCI A904 with Sizzler Torque Converter and 3.55s behind it.
lead me to water so I may drink...    :bigsmile:
« Last Edit: February 28, 2014 - 10:07:12 PM by LEMOOREACE »
« Reply #5 on: March 01, 2014 - 12:46:15 PM »
I would agree with the 702 grind
 not sure what the stall is with the Sizzler converter , but it would have to be higher than stock around 1600 rpm so you will be into the powerband with the 702 cam by the time the converter locks up , + as you can see you have similar duration to the XE Comp but with  approx. 10% better gain in lift , just make sure the valve clearance to the piston is adequate . Are you porting the heads at all ?
Offline LEMOOREACE
« Reply #6 on: March 01, 2014 - 07:16:30 PM »
Thanks Chryco,
The shop who is doing the valves asked if I wanted them to do some porting....   I looked online and saw some that have been worked and think I can pull it off at home, or should I let them?  Recommendations?
Just to to turn the heads around  (no porting) they said $450 labor plus parts, and quoted stainless valves at a buck cheaper than Summitt's Sealed Pros...
As for the TC "Expected RPM Stall Speeds:  Small Block:1500 to 1700 or 300-400 RPM increase in stall over stock, Quicker acceleration
Improved low end power & smoother running in stock or mildly modified engines".
« Last Edit: March 01, 2014 - 07:24:41 PM by LEMOOREACE »
« Reply #7 on: March 01, 2014 - 08:41:58 PM »
I do a lot of port work to heads , some is easy matching intake & exhaust openings , removing the lip behind the valves but do not taper the exhaust floor leave it as vertical as possible to drive the air flow to the roof , also making a wing shape around the guide can not only reduce drag & turbulence but can speed up one side enhancing swirl . depends what you feel capable of doing . cleaning guides & seats seems ok for the heads assuming that is what they are doing .
Offline LEMOOREACE
« Last Edit: March 04, 2014 - 05:49:59 PM by LEMOOREACE »
« Reply #9 on: March 04, 2014 - 11:43:51 PM »
Similar product , Hughes can be difficult to deal with , Engle used to grind all of Hughes cams , no warranty from Hughes , no problem from engle .
Offline FISH FRY
« Reply #10 on: May 13, 2014 - 08:41:54 AM »
 :wavingflag: :wavingflag:
whats your rear end ratio ? 3;50   run purple , or lunati equvalent
