Author Topic: Power Steering ?  (Read 877 times)
Offline BadJoey
Power Steering ?
« on: July 16, 2011 - 08:14:36 PM »
On the way home today I thought I smelled smoke but figured it was exhaust fumes . Go to my brothers to drop him off and smoke was coming out from hood . Upon opening it there was power steering fluid on  the inside fender wall and the headers as well as the master cylinder . Cleaned everything up but could not find any leaks . Got to my house and everything was wet again . Cleaned everything again filled everything again , reved engine , worked steering wheel , no leakes . Where is my leak coming from . Not hoses or seals .I know one of you have gone though this if you could help me out I would be greatful . Thanks . :bigsmile:
Re: Power Steering ?
« Reply #1 on: July 16, 2011 - 08:17:19 PM »
Had a similar experience with a Dakota P/U... only leaked bad when I turned the wheel,  High pressure hose fixed it
Offline BadJoey
« Reply #2 on: July 16, 2011 - 08:33:53 PM »
Hose new about a year ago , which I know doesn't mean anything . I did work the steering wheel while car was sitting and nothing . I'm wondering if there is a valve someplace sticking sometimes forcing it out the cap although the pump it self does not look rel wet just lightly . :clueless:
« Reply #3 on: July 16, 2011 - 08:43:11 PM »
Have someone rev. it up & turn the wheel while you look.   There is a seal under the valve where hoses attach.
Offline BadJoey
« Reply #4 on: August 13, 2011 - 01:44:49 PM »
Update :
Problem still there . I'm narrowing it down though .
First : only happens after 15 or 20 miles of driving .
Second : When it happened today (all at once smoke coming out of back) I pulled over and pump fill neck was wet .
Third : Got home cleaned things up , let car cool , no leak '
Here is what I notice under hood after 3 drinks steering trying to figure it out . One of the header tubes is touching the gear box .
Question what is the odds that the fulid is boiling over and out of the cap after 15 or 20 miles . And why now all of a sudden ? Motor not running any hotter that I can tell . Will denting  :screwy: the pipe be the anwser ?
Feed back please . Ever happen to anyone you know of ? Getting sick of keep cleaning when I want to be driving . THANKS  :worshippy :worshippy
« Reply #5 on: August 13, 2011 - 01:51:47 PM »
I installed a cooler for the steering fluid as my steering box is VERY close to the header too. The pump would get quite hot after a drive. The cooler did drop the temp quite a bit. I can't say for sure that's your problem as I installed mine before I started driving it.
Offline BadJoey
« Reply #6 on: August 13, 2011 - 08:44:36 PM »
Thanks Brad where did you get your cooler/ PS radiator ?
« Reply #7 on: August 13, 2011 - 11:05:26 PM »
A member on here set me up with it. I think he said it's off of a later model Sebring?
A small tranny cooler would work just as well too.
Offline BadJoey
« Reply #8 on: August 15, 2011 - 06:26:08 PM »
I ordered the cooler on page 3 for $31.95 with FREE shipping .
http://www.summitracing.com/search/Part-Type/Fluid-Coolers/?keyword=fluid+coolers&page=3
