Author Topic: E body auto to 4 speed question  (Read 806 times)
Offline John A
« on: July 16, 2011 - 11:32:28 PM »
When converting to a 4 speed in a E body does the factory installed rear console bracket have to be removed? Will the carpet fit over it or should it be removed? Thanks John.
Offline femtnmax
Re: E body auto to 4 speed question
« Reply #1 on: July 17, 2011 - 06:45:40 PM »
I did the auto to 4 spd swap.  I did not remove the rear console bracket, had hopes of attaching some sort of center storage/cup holder like on newer cars/trucks.   The 4 speed carpet fits over the bracket no problem.  When installing the carpet I ran two bolts w/ captive washers thru the carpet into the console bracket just to keep the carpet located during installation.  The two bolts are still sitting there, I just haven't found a center console I like.  If you find one you like let us know what you chose.  New ideas are always good.
If you need other general info on the swap, in the archives I submitted a post for auto to 4 speed swap.
Phil
Offline John A
« Reply #2 on: July 17, 2011 - 07:18:20 PM »
Thanks for the reply. I forgot to mention I will not be using a center console. Did 4 speed e bodies come from the factory without the console? Thanks John.
Offline _Russ_
  • Not very family friendly!
  • Chk Chk Boom!
    • Show Me How To Live
« Reply #3 on: July 17, 2011 - 07:44:29 PM »
Yep. Centre console was an option.
Offline Grec
« Reply #4 on: July 18, 2011 - 07:01:48 PM »
If you're going no console, you'll need to remove the rear bracket, otherwise you're gonne end up with a really weird looking bump between your seats.
1973 Challenger Rallye
- 440 Six Pack
- A833 4 Speed, 18 Spline
- FE5 Rallye Red on Black
