Author Topic: Alt going to full charge  (Read 1110 times)
Offline purple1
  • Worlds first e-body trailer. Member since 3/10/05
« on: July 17, 2011 - 08:42:22 AM »
I took the car out to the local cruse last night. I noticed at times the alt gage going to full charge. It was also making the lights very bright. What will make an alt go to full charge?
I'm sure given enough time I can figure it out, but I thought I would ask here first. Car was running fine when this was happening as well.
Worlds first e-body trailer.    Severna Park, Maryland
Re: Alt going to full charge
« Reply #1 on: July 17, 2011 - 12:53:41 PM »
The voltage regulator could have gone nuts. I had one that did that shortly before it died.
« Reply #2 on: July 17, 2011 - 01:44:50 PM »
I believe the VR regulates the voltage by varying the resistance to ground of the field wire. 0 ohms to ground being full field. I would think your VR is going south.
Offline purple1
« Reply #3 on: July 17, 2011 - 03:11:47 PM »
Thanks guys. I will try another voltage regulator. I keep one in the console. Think the mice problem I had could have had anything to do with this?
« Reply #4 on: July 17, 2011 - 10:18:38 PM »
the green ground wire from the alt to the reg would have to short to go to full charge , my Bet is the reg also , often the rubber seal in the back opens up & water gets in & shorts it , The one in my 89 Cummins truck failed every year this way
Offline purple1
« Reply #5 on: July 18, 2011 - 12:25:21 PM »
Thats what I was looking for. I will check it out tonight. If those little rodents chewed on the wires it could be whats going on. I'll replace the reg anyway, it is one of those cheap chome jobs. I'll let you know what I find.
Thanks CP
« Reply #6 on: July 18, 2011 - 12:54:19 PM »
 :2thumbs:
not many places the green wire could short , except along the rigth valve cover , ususally well wrapped in tape
Offline purple1
« Reply #7 on: July 19, 2011 - 07:47:53 AM »
I think you guys were right. I did not find any chew spots along the wires, the engine harness has been repaired before I ever got the car, but nothing looked bad. I swapped out the reg last night and started it up. So far so good. I will know for sure after I go for a cruse this weekend. Thanks again.
Offline purple1
« Reply #8 on: July 24, 2011 - 09:27:29 AM »
I think this problem is solved. I took out the car yesterday for over an hour drive and had no more problems.
Thanks guys, I knew this was the right place to ask first.  :thumbsup:
