Author Topic: Shaker Seal to Adapter Installation?? 3M Rubber Trim Sealant?  (Read 1717 times)
Offline chaps70rt
  • 70 Challenger R/T Hardtop in Progress (Canada)
Just finished installing my trunk seal with the 3M product/adhesive.  Can I use the same to attach my new seal to the shaker adapter ring??
Or is contact cement better/worse?    Only saw one previous topic on this and was wondering if anyone has found a better product for this application with the heat around the motor.
Thanks  .... CHAPS :feedback:
White 1970 Challenger R/T
440 - 4BBL - Shaker
Daily Driver - 2014 Dodge RAM 1500
Stouffville, Ontario Canada
Re: Shaker Seal to Adapter Installation?? 3M Rubber Trim Sealant?
« Reply #1 on: July 18, 2011 - 10:02:26 PM »
3M weatherstrip is a good product & should work well for the shaker seal , I would use making tape all the way around to hold it in place while the glue drys
Offline chaps70rt
« Reply #2 on: September 11, 2011 - 08:32:28 AM »
Thanks Chryco ...... that worked pretty well.   I had to clamp it in 8" sections, but it works.
Do you happen to know where the proper location is for bolting the feet to the intake manifold is??  I got these from Dave at Roseville for my 440-4BBL shaker set up, but I am unsure which intake manifold bolts they are supposed to attach to (OEM set up).    There is no reference to the shaker set up in the Service Manual.
Cheers ..... CHAPS!
440 - 4BBL - Shaker
« Reply #3 on: September 11, 2011 - 09:26:23 AM »
only the single 4 bbl base had feet to stop it rotating  as far as I know , I never figured them out either
