Author Topic: Starts when you let off the key.....  (Read 4008 times)
Re: Starts when you let off the key.....
« Reply #15 on: July 31, 2011 - 11:26:12 AM »
In your case since you removed the trans, check your neutral safety switch.  If its an auto, make  sure  shifter  is adjusted right.  Will it start in "neutral" or "park"?   Can't help with manual shift.
That only effects cranking, his car is cranking or it would never start.
Offline wally426ci
    • maryland mopars
« Reply #16 on: July 31, 2011 - 12:39:44 PM »
And Ive had the nuetral safety grounded at the relay for about 9 years now.  :bigsmile:
Thanks for checking in. I promise to report back when I ever get time to wrench.  :working:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline cwestra
« Reply #17 on: July 31, 2011 - 04:51:17 PM »
I just fixed the problem.  Seems it was related to the R&R of the trans afterall, in a way.  When I installed the electronic ignition last year I had to spice a new wire into the feed side of the ballast resistor.  Apparently I did not have a great connection between the spliced wires and when I was fishing for the neutral start switch wires to reconnect them to the trans I must have snagged the ballast feed wire in the process, pulling the original feed end loose from the spice.  Reconnected it and the car fired up.  Just thought I'd pass it along.
Glad it was a simple (no cost) fix.  Now on other things.
Corey - in Northern Indiana
Offline 73EStroker
« Reply #18 on: August 02, 2011 - 10:26:52 PM »
I had a similar issue on my 73. Was the firewall connector for the bypass supply to the coil direct from the ignition while it is cranking. Would fire when the key was released. With my Mallory digital system all I did now was jumper them both together as the ballast resistor - shes a gone!
Barry (Salmon Arm)
