Author Topic: Dana 60  (Read 580 times)
Offline Schimms15
Dana 60
« on: July 18, 2011 - 11:38:15 PM »
Can I throw a 1980 f-250 dana 60 on the back or is it way off?
Willys cj-2a 1946
Re: Dana 60
« Reply #1 on: July 19, 2011 - 09:41:22 AM »
it will work , it costs about $!000 to modify it , the floating axles & housing ends need to be cut off & replaced with the 5 bolt car ends & new axles ordered
Offline aris_unlimited
  • Project in full swing
Re: Dana 60
« Reply #2 on: July 19, 2011 - 06:33:06 PM »
Any dana 60 will fit you will just have to have it cut to the appropriate length, and possibly have the spring perches put in a different spot.
I am going to be paying about $2k, to have mine sized and rebuilt to my specs.
Cuda is gone :(
74 satellite, daily driver/project now
Re: Dana 60
« Reply #3 on: July 19, 2011 - 07:57:09 PM »
you dont want the dana with the anti lock ring gear, and you dont want a van dana they are like a dana 61, you also want the dana to be a 3/4 ton and not a 1 ton. Axle tubes very in thicknes. The dana you have will fit the bill with no problems. You will have to cut your driveshaft down an inch less than your 8 3/4. It is more like 15/16ths, but 1 inch is good.  Doc differential makes a weld on snubber kit for under 60 bucks. Really easy to install, I recomend using it. When you weld the axle flanges on, remember to get the correct pinion angle on them so you dont have vibration issues. Wedge shims take up need space off of your u bolts
