Author Topic: Power steering hose?  (Read 561 times)
Offline ajantics
    • Yeah......Im a drummer!
« on: July 21, 2011 - 04:40:21 PM »
 I am installing a new march performamce power steering pump his weekend on my 73 cuda with a 340. I just wanted to know if I needed new hoses to make it work, and If I do could you tell me what size I need?
the specs on the mach pump are.
Inlet Attachment  Hose barb
Inlet Size  3/8 in.
Outlet Quantity  One
Outlet Attachment  Inverted flare
Outlet Size  5/8-18 in. inverted flare
 :2thumbs:
http://www.summitracing.com/parts/MCH-9600/
70 Barracuda
73 'Cuda
2003 Dodge Ram 3/4ton
2009 G37s
Re: Power steering hose?
« Reply #1 on: July 21, 2011 - 11:58:51 PM »
Info I had posted on a high pressure hose..looks like the same #s
w/ Saginaw Pump
P/S Pressure Hose - OEM
Product Line:   NAPA Power Steering Parts
Part Number:       NPS 7610
Price:
Price
Unit
   22.99
Each
Features & Benefits       To Ensure Highest Level Of Performance & Long Service Life, Built & Tested To Most Stringent Specifications In Industry, Using Specific Product Features As OE Helps Guarantee Easy Installation & Proper Fit
Warranty       Limited Lifetime
Attributes       Contents : (1) Hose
Manufacturer : Plews Edelmann
Manufacturer Part Number : 70344
P/S Hose End Type : 5/16" Female S.A.E. x 3/8" Male Inv. Flare
Power Steering Hose Imperial Length : 34 1/4"
Material Safety Data Sheet       There is no MSDS for this item
Application Information:       1970 Dodge Challenger
Engines : 5.2 L 318 CID V8
Comments: w/ Saginaw Pump
Per Car Qty: 1
Engines : 5.6 L 340 CID V8
Per Car Qty: 1
[/quote]
Offline ajantics
« Reply #2 on: July 22, 2011 - 02:05:26 PM »
Thank You very much Bullitt-  :2thumbs: :cheers:
70 Barracuda
73 'Cuda
2009 G37s
