Author Topic: Fuel sending unit install  (Read 2259 times)
Offline lime73
« on: July 22, 2011 - 04:21:21 PM »
Is there any prep needed to install a new sending unit or just unwrap it and throw it in?  thanks for all your help
Offline tommyg29
Re: Fuel sending unit install
« Reply #1 on: July 22, 2011 - 05:18:28 PM »
no big deal. Just make sure you replace the gasket if it is old, and make sure the tabs click into place when you twist it back in.
Offline Matt70
« Reply #2 on: July 22, 2011 - 05:23:02 PM »
A lot of folks have ground problems with these. I would go ahead and solder on a ground wire just for gp.  :2cents:
People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf.
George Orwell
Offline cuda341
  • Newbie
« Reply #3 on: May 02, 2013 - 04:54:30 PM »
Do you have to drop the tank?
Offline dutch
« Reply #4 on: May 02, 2013 - 04:57:45 PM »
nope.
welcome to cc  :wave:
*** Bart ***
« Reply #5 on: May 02, 2013 - 07:03:48 PM »
No, and it's not too difficult either. Just make sure you have less than 1/2 tank of gas when you remove the sending unit.
Offline Jamiez
  • Retro
« Reply #6 on: May 02, 2013 - 07:22:05 PM »
Some people had trouble with repopped lock rings and ended up using their originals..
You will have to pull the heat shield if it's in place and it can be a bit tricky to remove depending on your muffler/exhaust set up.
Offline JayBee
« Reply #7 on: May 02, 2013 - 07:26:21 PM »
As a precaution I'd test the float for leaks first, especially if it's a brass one. Dunking it in water and looking for bubbles now may save some grief later.
John
1970 Barracuda convertible
2014 Toyota Avalon
Offline hooD
  • detroit iron
  • Motor City Made Muscle
« Reply #8 on: May 03, 2013 - 05:10:09 AM »
Shake it to make sure it is empty...if you hear or feel liquid inside of the float, get a new one.
My float had a major leak as you can see...
Drivers side heat shield needs to be removed.
BEFORE PICTURE: clean up the metal ground strap and use a dab of dielectric grease on the sending unit press on connector
-Larry
member since AUG 2007
southeastern michigan usa
1973 'CUDA 340
original owner
37,117 miles
