Author Topic: Temp gauge wiring help  (Read 3783 times)
Offline joepharaoh
  • cars...they're a sickness only cured by poverty
« on: June 03, 2002 - 05:09:41 AM »
Hello,
Can someone tell me the temp gauge wire color from gauge to sending unit. I tried to follow the FSM that I have but it just shows the wire connection in a bulk run rather that separate. Oh yeah, it for a '73 Barracuda
Thanks
« Last Edit: December 31, 1969 - 07:00:00 PM by 1023595200 »
Offline joepharaoh
Re: Temp gauge wiring help
« Reply #1 on: June 04, 2002 - 06:04:48 PM »
I had another reply with violet.  ???
How can I re-wire the guage using a separate wire? Does the original wire run through the fuse block the to the sending unit in the Water pump housing?? If so, which fuse is it attached to?
Thanks.
Offline 71 DEPUTY
  • IF YOU CAN'T DODGE IT--RAM IT!
    • Cardomain
« Reply #2 on: June 04, 2002 - 08:22:29 PM »
sorry- I looked at a old harness and someone had changed it- looked at the manual book and it is violot.
well you can feed another wire from the sending unit to the firewall connector- it is # 21 on the block- if correct- look at the right hand connector block- upper right side- the same violet colored wire.
there is no real fuse for just the sending unit- it shares the same voltage of 5 volts from a limiter on the back of the dash. the fuse for it is the accessory fuse #6 which is 20 amp fuse.
it also would power the air cond.clutch or rear def.
Offline joepharaoh
« Reply #3 on: June 05, 2002 - 05:33:56 AM »
Thanks 71 Deputy.
I will look at it on Friday. I will try a new wire for a test. I think I will just put an aligator clip on the test wire and connect it to the gauge and sending unit to see if this works.
Thanks again. :D
