Author Topic: 440  (Read 1460 times)
Offline Schimms15
440
« on: July 27, 2011 - 01:53:32 PM »
There's two used 440 on craigslist. If I went to look at them what should I look for. One is 300 the other 1200
Willys cj-2a 1946
Offline Matt70
Re: 440
« Reply #1 on: July 27, 2011 - 05:07:19 PM »
People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf.
George Orwell
Re: 440
« Reply #2 on: July 27, 2011 - 06:46:25 PM »
I'd say it depends on what your plans are? If you plan on rebuilding it anyway ( core) then go for the cheapest option. If it's a running engine your after and don't have a big budjet.... check compression, look at head casting #'s check the oil ( clean/dirty)
Re: 440
« Reply #3 on: July 27, 2011 - 07:11:02 PM »
If not running, you need to pull the heads and check bore, also check lifter valley for cracks from a hard freeze.  CDEFG blocks are for the most part, steel forged crank engines.  Before pulling heads, see if the engine spins over by hand first. Take an 1 1/4 wrench with you or socket extention and ratchet.   To rebuild a 440 back to fresh is around 12-1500 bucks. As you step up into performance and around 3k for start
Offline Schimms15
Re: 440
« Reply #4 on: July 27, 2011 - 09:42:07 PM »
When you say rebuild what are you including?
Willys cj-2a 1946
Offline Matt70
Re: 440
« Reply #5 on: July 27, 2011 - 09:51:18 PM »
If you plan on building a motor (pistons, alluminum heads, forged crank, stroker kit etc.) and all your worried about is the block then go cheap (price not material). If you are just looking for a running motor then there is more to it like Brads70 said.
George Orwell
Re: 440
« Reply #6 on: July 28, 2011 - 12:54:31 AM »
 to do block prep
re ring, bearings, turn crank,  valve job, cam n lifters, timing chain, oil pump, clean all covers and gasket set.  This is a basic keep it simple rebuild like this. Useing the block dates above helps with the compression, then finding 66-67 date heads will give you an increase in compression, but and about 325 more to the cost of installing bigger valves, hardened exhaust seats and a better valve spring set up.
