Author Topic: Cuda Rear Louvers  (Read 971 times)
Offline HemiTunis
Cuda Rear Louvers
« on: July 29, 2011 - 05:38:57 AM »
Hi,
Just some question about rear window louvers.
Would you drill hole in your Cuda to install these? And if you did, what is the best way to seal up the holes?
I think they look really great but I don't want to mess up my car...
What is your opinion?
Per
Per from Sweden
Vehicle fleet:
1971 472 Hemi 4-speed Cuda, under restoration
The one(s) that had to go to move forward in life:
1968 Dodge Charger R/T
1970 340 4-speed Cuda, matching numbers
Offline Grec
Re: Cuda Rear Louvers
« Reply #1 on: July 29, 2011 - 06:32:41 PM »
I plan on installing them at some point. So yeah, I'd drill the holes. :-)
I know they have rubber gaskets that go under the hinge plates, but I'd probably put some kind of sealant on the screws just to be sure.
1973 Challenger Rallye
- 440 Six Pack
- A833 4 Speed, 18 Spline
- FE5 Rallye Red on Black
« Reply #2 on: July 29, 2011 - 06:38:20 PM »
I used nutserts on mine.( Challenger louvers) Same thing you use to install the door mirrors. Before I installed the rivit ( nutsert I sealed the hole with permatexs gasket maker, ran some around the head of the rivit too before it was installed. After it was installed I wiped  the excess off. It also does come with a rubber gasket around the base of the hinge too.
Hope that helps?
Offline HemiTunis
« Reply #3 on: July 29, 2011 - 07:02:44 PM »
Yes, that helps! I always have to think a couple of times before making some irreversible (well not totally but still) changes to the car. Thanks Brad and Grec!
Per
Per from Sweden
Vehicle fleet:
