Author Topic: Creaky steering wheel  (Read 729 times)
Offline bandt
« on: July 29, 2011 - 11:05:13 AM »
Hi Guys,
Did a couple searches, no hits.
My steering wheel starts to develop a creak as it warms up with the car. Its coming from the crush can. Sounds like plastic on plastic kind of a binding sound.
Think I'm going to have to pull it apart. Got another stupid question how does the horn button come off of a standard wheel?
Thanks,
Brian
Re: Creaky steering wheel
« Reply #1 on: July 29, 2011 - 02:13:58 PM »
Just below the crush can is the column bearing. Maybe it is getting stiff?
Hi Guys,
Thanks,
Brian
Just pull it offwith your finger tips.
Offline bandt
« Reply #2 on: July 29, 2011 - 06:01:01 PM »
Thanks,
Got the can off. Can see the bearing seal is torn. Assuming its bad bearing. Now I think the ignition cylinder is next but not sure how to get that out either.
Brian
« Reply #3 on: August 01, 2011 - 12:24:06 PM »
lube the brg , I have rarely seen one go bad
 the ign lock is release with a push clip behind the lock tab retainer held with 2 large phillips screws
Offline bandt
« Reply #4 on: August 01, 2011 - 02:33:00 PM »
Great Neil,
Will do.
Brian
Offline UKcuda
  • Tell them I'm on my way
« Reply #5 on: August 09, 2011 - 04:37:27 AM »
I've dealt with steering that creaked when it got warm but it was on my '72 Mustang so maybe not the same deal but worth a mention perhaps.
Anyhow it was fine when cold but as it warmed up I could hear it like you describe and I could also feel it through the wheel.  I changed the fluid for proper steering fluid and it cured it.  It looked like someone had put transmission fluid in there.
'72 'cuda
