Redline rebuilt my cluster. Speedo was refaced, calibrated, zeroed, and greased. Temp gauge was calibrated, and rescreened with actual numbers in addition to just H and C. The amp meter was converted to a volt meter. And I had the oil pressure gauge added where my clock was. I added a 3.5 inch Sun Tach to my column so I can still see my "stock" gauges and have an old skool look. Everything works fine.
Is my original clock worth anything? I just have it in a box now doing nothing. Cody makes it sound a bit rare.
I purchased the tach that fits in the clock hole, but decided it was better to have the oil pressure up high where I could see it, and add the column tach next to it. Now I have lots of info up high instead of having to look down to see extra gauges.
