Author Topic: installing the rear spoiler 1971  (Read 3536 times)
Offline high perf mopar
« on: July 30, 2011 - 11:47:48 PM »
i dont know if anybody has had this problem but this is what i did today..
when installing the rear go-wing on the 1971 deck lid u get bowing on the deck lid sheetmetal when tighting the hold downs..using the install kit provided,since its pulling down against a unreinforced piece of sheet metal,,so what i did was fab a aluminum plate that goes under the pedestal under the deck lid and fab aluminum tubes that the bolts/bracket would tighten against..then install the deck lid bracket in the trunk and tighten it all down,,no more bowing from being pulled down to tighten the whole assembly up.because its being pushed up from below..no pics since its all installed and u could not see it anyway,,
anybody else have this problem????
« Last Edit: August 06, 2011 - 12:16:58 AM by 440 »
1971 barracuda
440-6 shaker
chrysler 3x2 competiton carbs mech,what chrysler should have done.
b-5 blue
"you got yourself some motor there boy!" 1973,,white lightning.MGM studios burt reynolds
Offline mopardave
  • Sponsor
    • rosevillemoparts
Re: installing the rear spoiler 1971
« Reply #1 on: July 31, 2011 - 07:55:17 AM »
the question is how many nuts did you get in this kit, 4 or 8, you should have received 4 speed style nuts to hold the spoiler to the deck skin, then 4 2 piece adjusting nuts that hold the weight of the spoiler so the skin does bow or pull in.
« Last Edit: July 31, 2011 - 08:00:35 AM by mopardave »
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
« Reply #2 on: July 31, 2011 - 11:11:39 AM »
well that explains it...my kit that came with the car new in the box did not have those cone shaped nuts,,i will have to get a set but its fixed for now..just goes to show u not all kits r alike..thanks for the reply..
1971 barracuda
440-6 shaker
b-5 blue
Offline dutch
« Reply #3 on: July 31, 2011 - 03:06:13 PM »
hey 440,  sorry for the off topic,  that`s one sweet ride you`ve got there  :2thumbs:
I was wondering how you like the cooper tires.  I`ve been thinking about those.... I like the white letters and don`t want to go with BFG`s  :grinno:
*** Bart ***
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #4 on: August 01, 2011 - 07:56:08 PM »
Bart,
we sell a lot of Coopers here at the dealer.Cooper is a good shoe to put on. just my  :2cents:
Mopar Dave
73 F8 Challenger
1990 XJ - sold
« Reply #5 on: August 01, 2011 - 08:40:02 PM »
the coopers seem to be pretty good..and hook up well too.the motor has a power band like a 2 stroke engine,,the outboard carbs open up around 3000-3200,right where the 555 lift solid cam is really coming on and at half throttle so far they grab..look good too,,had to get use to the name but the only other tire manf out there with a wide range of tires for us old schoolers is b.f. goodrich.
which i had on there at 1st but they broke loose really easy compared to these..275/60-15 rear,,245/60-15 front..goodyear no longer makes these sizes..theres just something about raised white letters on a classic muscle car :bigsmile:
« Last Edit: August 01, 2011 - 08:42:15 PM by 440 »
1971 barracuda
440-6 shaker
b-5 blue
« Reply #6 on: August 04, 2011 - 04:19:32 PM »
great looking car , but the wing seems to be tipped back to far , the bottom of the end of the wing should be about level with the ground
« Reply #7 on: August 04, 2011 - 07:09:53 PM »
thanks,,yeah the cars so new that im still working out small things like that,,its since been rotated up in back to around level..its been on jack stands the last couple weeks while im doing detail work getting ready for the monterey bay mopars show on aug 27th at the monterey wharf,,
it seems to be running good since i had to pull the motor back out last january and change the defective cam,,bad hydralic lifters,,kept dropping pushrods due to lifters bleeding off ..............
« Last Edit: August 11, 2011 - 12:52:47 AM by 440 »
1971 barracuda
440-6 shaker
b-5 blue
