Author Topic: Convert from non-Rallye to Rallye gauges  (Read 767 times)
Offline HemiTunis
« on: August 01, 2011 - 02:59:01 PM »
What I haven't figured out is if the switch bezel side (I don't know the name of it, the one with the panel dimmer)  is different? Is it sufficient to buy a wood grain face and put on there? Or are there any other differences?
Also, has anyone disassembled an Auto Meter gauge? I was thinking if it would be possible to use the internals of modern gauges and the face of the old gauges. I think the Auto Meter 1110 could be a candidate with correct sweep and it has the correct sweep for the voltmeter from left to right.
Per
Per from Sweden
Vehicle fleet:
1971 472 Hemi 4-speed Cuda, under restoration
The one(s) that had to go to move forward in life:
1968 Dodge Charger R/T
1970 340 4-speed Cuda, matching numbers
Offline TreeFrog
    • TreeFrog
Re: Convert from non-Rallye to Rallye gauges
« Reply #1 on: August 01, 2011 - 04:13:04 PM »
the Switch plat is different ... the heater control panel is different as well
87 Dodge Ram     318 Blue
88 Dodge Ram     360 Grey (+)
« Reply #2 on: August 01, 2011 - 04:41:29 PM »
The light bar is different too. Rally gauges have 4 lights instead of the standard 3.
I can't answer your question about the Auto Meter swap.
Offline HemiTunis
« Reply #3 on: August 01, 2011 - 05:12:30 PM »
Okay, great! Thanks for the help! Will see if I decide to buy a $250 gauge and destroy it, probably not..
Per from Sweden
Vehicle fleet:
