Author Topic: Electrical Voltages Needed  (Read 661 times)
Offline cwestra
« on: August 02, 2011 - 02:09:27 PM »
I have a friend with a '66 Charger who would like to know what voltages he should be getting at the following terminals.  Any help would be appreciated.
1) Both sides of regulator.
2)  Both sides of ballast.
3)  Alternator field.
4)  Alternator "Batt" running and off position.
5)  At coil.
Corey - in Northern Indiana
Re: Electrical Voltages Needed
« Reply #1 on: August 02, 2011 - 05:42:32 PM »
things work backwards on the 66
1- the regulator should have battery voltage at one side & variable on the other side out to the alt , in those years they regulated the power side not the ground side of the field
2 - 12 v into the ballast & approx 8 at the coil feed side
3 - Variable , same reading as the wire out of the regulator .
4 - 13v not running , 14.2 approx running
5 - coil should be battery v when cranking & drop to 8-9v Key on or running
Offline cwestra
« Reply #2 on: August 02, 2011 - 06:29:28 PM »
Much appreciated, CP.  I think I owe you a steak diner (at the very least) after all the help you've given me.  Hope I can make good on that promise someday.  For now though, thanks again.
« Reply #3 on: August 03, 2011 - 09:40:54 AM »
We will see what the future holds !
I was too far north to meet most of the members for the last 10 years , now I am too far south !!
I really wanted to attend more meets & events & meet more of the great people here but I definatly will not be driving to any anymore from here !!
