Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Engine & Go Fast Goodies
(Moderator:
Chryco Psycho
water pump pulley combos
« previous
next »
Print
Pages: [
1
Author
Topic: water pump pulley combos (Read 599 times)
e-chal
Jr. Member
on:
August 02, 2011 - 10:27:43 PM »
Bought the Mancinni alum high vol. pump and housing special (mre6900khv) and this came with the 6 blade (a/c) water pump with a backing plate spot welded to the back of the impeller. Going into a 451 engine with no a/c in car (1971 Challenger) and 26 in. alum rad, with shroud and viscous drive 7 blade fan. Should I use the non a/c combo of pulleys or the a/c water pump overdrive combo of pulleys? Car is strictly street driven with "enthusiasm".
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re: water pump pulley combos
Reply #1 on:
August 03, 2011 - 12:05:18 AM »
the factory AC pulley system will not work without the AC , my recommendation would be to use the non ac pulley set but you can talk to Mancini & see what they recommend , maybe their system would work without the AC pump
Logged
e-chal
Jr. Member
Reply #2 on:
August 04, 2011 - 07:04:57 AM »
Sorry Chryco about slow response. Talked to Mancinni as you suggested and they told me the same thing as you have said. Thanks
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
