Author Topic: Anybody have 15x10.5 on the back of their ride?  (Read 12637 times)
Offline UCUDANT
Re: Anybody have 15x10.5 on the back of their ride?
« Reply #30 on: August 12, 2011 - 09:10:34 PM »
Looks darn awsome man!!
Actually it was either a 7/16 or a 3/8th socket fits in there (sideways though)
Offline mopar12372
    • mopartech
« Reply #31 on: August 12, 2011 - 10:01:11 PM »
 here is what fits on my car . to get the mickey thomson  15x10 29x12.5  5.5 in   back space on the rims = tires to fit on my cuda.  the spring  relocation kit had to be used . they fit snug and look great . unfortunately i dont have pictures because i had to remove them to do the welding on my car. i have seen cudas and challengers with this same set up with a 4.5  back space but they rub the wheel wells pretty darn bad.
RESTO PICTURES
Offline UCUDANT
« Reply #32 on: August 16, 2011 - 01:37:00 PM »
 I'd need some detailed pics of that install. Are you sure you don't have a B body rear in that car?
   :useless:    I have a stock rear axle, 15x10" rims with 6" of back space and the spring perches relocated.8"  I have to say that if the wheel had .5" less of backspace that it would not fit under the car properly. If the ride height were high enough it would clear but I would not do it. I know a guy who rolled his fender lips because he had slightly less back space than I did. Pics of mine are included above in prior reponces.
« Last Edit: August 16, 2011 - 01:43:41 PM by UCUDANT »
Offline mopar12372
    • mopartech
« Reply #33 on: August 16, 2011 - 11:17:49 PM »
no problem ill take pictures and post them . the tires fit really good  with the caltracs abd mono leafs . i did a basic relocation kit with a stock e-body rear . i removed the mini tubs and put the car back to stock . didnt move anything butthe springs perches and used the offset hangers . did tou use the off set hangers ?
RESTO PICTURES
Offline mopar12372
    • mopartech
« Reply #34 on: August 16, 2011 - 11:32:48 PM »
ok found a picture  if you need more let me know plz.
RESTO PICTURES
Offline UCUDANT
« Reply #35 on: August 17, 2011 - 03:21:41 PM »
I used the offset MP rear spring hangers. If you were to fully compress the rear suspension will the cars inner wheel lip clear the buldge in your tire? IE does the tire fit "under" the car completely?
Offline mopar12372
    • mopartech
« Reply #36 on: August 17, 2011 - 08:22:29 PM »
the car sits one inch lower than what you see thats the way i like it.
RESTO PICTURES
Offline RDF
  • The pain that greets me is the stick that beats me
« Reply #37 on: August 18, 2011 - 09:18:06 AM »
I like this look a lot.... :2thumbs:  being clueless to relocation kits, how much does the kit allow for the springs to be relocated (in inches)?  In other words, are there some kits that allow 1" while other kits allow 4"+?  :clueless:
How much did those rims cost?  Are those Welds?
Bob
1973 'Cuda
If we never drown we'll never know how well it tastes....So tell me how it tastes and I'll know just how well you drowned.
My build:
http://www.cuda-challenger.com/cc/index.php?topic=45749.0
« Reply #38 on: August 19, 2011 - 09:08:50 AM »
There are essentially three spring relocation kits on the market. Mopar makes one that pulls them in .75 per side. Dr Diff makes one that pulls them in 1" per side. Both of these utilize offset brackets and shackles. They also will require moving the springs perches on the axle housing in the corresponding amount, or another popular swap is to use a 68-70 B body rear housing whcih drops in to place on the new spring location. The third kit is the 3" per side pull in which requires cutting in to the frame rail and replacing it with the boxed section that then becomes the front hanger for the leaf spring.
Offline mopar12372
    • mopartech
« Reply #39 on: August 23, 2011 - 09:57:56 PM »
the wheels are weld aluma stars with mickey thomson 15x10x 29   12.50 15 5.5 back space . fronts are 15x7 . they are close 1/2 inch side to side .
 i have the weld in kit 3in with the off set hangers . the car will sit 1 in lower  when the engine / trans ect is in . as far as rubbing well unless you minitub or back half the car no matter what you do the big tires will rub one way or another it just depends on how much and where it rubs .  i get a little rubbing on the inside when you go over bumps really hard .
RESTO PICTURES
Offline RDF
« Reply #40 on: August 24, 2011 - 01:53:07 PM »
what size tires do you run in the front?  and what's the 12.50 15 ?
Bob
1973 'Cuda
My build:
Offline mopar12372
    • mopartech
« Reply #41 on: August 24, 2011 - 09:47:54 PM »
10 rim width
15 rim height
29 tire height
12.5 tread width
RESTO PICTURES
Offline HEMROID
« Reply #42 on: August 29, 2011 - 02:32:36 AM »
My rear's aren't overly fat but fill it out nicely with no scrubbing... 275/60 BF Goodrich Radial T/A on 15x8" Rallyes. Pretty common set up I think.
Matt
1970 Dodge Challenger R/T 440 Six Pack (clone)
2008 Lexus IS F
Offline mopar12372
    • mopartech
« Reply #43 on: August 29, 2011 - 06:45:24 PM »
you mean section width right?  :working:
yes  hahaha
RESTO PICTURES
Offline RDF
« Reply #44 on: September 09, 2011 - 12:03:32 PM »
Thanks to all who have posted in here....I am taking the beast tomorrow to get a bunch of work done to it and the guy will have a look at the back-end and offer his advise on wheels and how much to put on before having to "modify" anything.  He's a real straight-up type of guy and comes highly recommended by a lot of people....plus he's worked on all my neighbors cars (69 Dart, 69 Hemi Cuda, 68 Hemi Dart clone) so I've gotten to see his work first-hand.  We will most likely go with a 15x8 rim but will talk more about the tire once we get it all figured out.   :2thumbs:
Bob
1973 'Cuda
My build:
