Author Topic: help me get my 6 pack 340 tuned!  (Read 5479 times)
Offline The4ork
Re: help me get my 6 pack 340 tuned!
« Reply #15 on: August 11, 2011 - 09:18:22 PM »
here is the video click the picture
Offline The4ork
« Reply #16 on: August 11, 2011 - 10:00:07 PM »
friend of mine who knows holleys says it sounds like i have a bad power valve.
any suggestions on that? should i just replace it anyways? it looks cheap... like $8 plus some gaskets to split the carb apart.
should i also get some jets as well? i forgot to mention i have #62 jets
and whomever said it had a lean condition before. its definately 'loading up' with gas, plugs are sooty, its throwing fuel and sometimes a fireball out the carbs. mostly the center carb
« Reply #17 on: August 11, 2011 - 10:09:15 PM »
They way your system look I would go through all 3 carbs , it seems someone patched it together to make it work , I would swap the power valve , but measure the vacuum first , you need to have 2" more vacuum than the power valve rating idling in gear if auto so if you have say 10" of vacuum put in a new 6.5 PV , but if you have 6" go to a 3.5 PV
61 was the stock jet so you are good with 62
Could be bad gaskets , PV , Fuel level , or other internal leaks causing the flooding or loading
« Reply #18 on: August 11, 2011 - 10:17:27 PM »
so you need to take apart the linkage & move the bushing behind the slider link so it will not force the end carbs open but instead close them
Offline The4ork
« Reply #19 on: August 12, 2011 - 09:48:27 PM »
ill try that, if not i found some linkage on ebay.
Offline The4ork
« Reply #20 on: August 13, 2011 - 01:20:56 AM »
runs smoother. i have a new power valve im going to install tomorrow, well ill at least pull the orig. one out and see if its bad.
a friend of mine dropped me off a free holly 600 4bbl tonight. tempting
« Reply #21 on: August 13, 2011 - 09:10:52 AM »
We will get the 6 pack working OK , the 600 is too small but ti would run with it
Offline The4ork
« Reply #22 on: August 13, 2011 - 11:34:00 AM »
My friend says if get the 6pack and got it to run perfectly I'll be under the hood retuning it every two months, is that true?
« Reply #23 on: August 13, 2011 - 05:55:36 PM »
no , I tuned a 6 pack for a friend back in 79 , it has changed owners but it has not been tuned since
Offline 72cudamaan
« Reply #24 on: August 15, 2011 - 05:09:36 PM »
Sure sounds like your "friend" wants your 6 pack set-up. He'll say anything to get it.lol   :roflsmiley:
If I cant fix it, it's broke
Andy  (phukker whither)
Offline The4ork
« Reply #25 on: August 16, 2011 - 02:45:37 AM »
I tried a new power valve and put new gaskets in the center carb and new idle needle corks.... Well no more backfiring but it filled my whole street with smoke! It's SO rich!!!!!
Could bad gas cause that? Not burning efficiently?
I have to keep it floored to start it. After about 4 or 5 seconds it will slowly come to life but I have to keep my foot in it to stay running.
Wonder if I need a different pv? I have one more I can try tomorrow. Then I'm outta ideas :(
« Reply #26 on: August 16, 2011 - 09:19:14 AM »
probably a bad needle & seat causing it to flood on one or more of the carbs
Offline The4ork
« Reply #27 on: August 16, 2011 - 07:18:54 PM »
explain in more detail. im still getting out of fuel injection mode and into carb mode
can you guys help me find the correct linkage for the outboards? ive been searching for days and coming up short. all i can find are kits priced at hundreds. for a stupid rod and some bushings.
« Reply #28 on: August 17, 2011 - 09:08:49 AM »
the linkageyou have will work , he kits to get the linkage are $250
 the needle & seat are the adjusters on the top of the carb / fuel bowl , if you remove the sight plugs on the side of the bowl  fuel will be spilling out of one or more of them , remove the neddle assy from the top of the carb & clean it or replace it & reset the float level
Offline The4ork
« Reply #29 on: August 17, 2011 - 08:24:26 PM »
well ive decided to ditch the 6 pack and go for a 4bbl. i have a 650cfm 4 barrel with the electric choke i got for free! just need an intake manifold and some gaskets. shopping around on summit right now.
