Author Topic: just cant spin em  (Read 3240 times)
Offline joef89
  • 74 Challenger RT
just cant spin em
« on: August 12, 2011 - 11:05:47 PM »
So i put in a new comp cam kit and changed out the carb, but now i just cant break the tires no matter what. it pisses me off. i tried to roast them when i was on brice rd and just couldnt do it.
Offline footin70rt
Re: just cant spin em
« Reply #1 on: August 12, 2011 - 11:13:40 PM »
It could be a matter of the combination. What are the specs of the cam, what gear ratio, and what gears are you running? And is this a big block or small block? It could also be a tuning issue, How did it run before the cam swap?
Thomas
Driving the same 70 R/T since October 1985
Native of Bozeman, MT
Offline GoodysGotaCuda
« Reply #2 on: August 12, 2011 - 11:15:22 PM »
torque converter = night/day difference if it's stock or a cheapie off the shelf. :2cents:
1976 Dodge Warlock
Wheel & Tire Specs:Link
« Reply #3 on: August 12, 2011 - 11:16:20 PM »
 Sorry to hear that, I'm sure some of the mechanical guru's here will be able to help you through it soon.
 I'll just say that mine would hardly turn over a tire back in the day with a one legged diff. but by paying attention to how to set the ignition timing and carburetor tuning my more or less stock low compression 340 lights them both up easily through a posi rear.
Offline joef89
  • 74 Challenger RT
« Reply #4 on: August 13, 2011 - 07:01:04 PM »
its a stock 360 Sb with a 2500 stahl, 355 posi, it coudl light it up before the cam,
heres the info about the cam http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=627&sb=2
Offline 6packCuda
« Reply #5 on: August 13, 2011 - 10:08:21 PM »
You're going to have a little less on the bottom end with that cam but should have more on the top end. How's it run once you get going?
« Reply #6 on: August 13, 2011 - 10:37:42 PM »
       Ya know this is in the wrong section if your looking for technical advice, & the title doesn't convey the situation.
  Try posting in the Tech section under Engine & Go Fast Goodies with a title more along the lines of New Cam Low ON Power.
Offline joef89
  • 74 Challenger RT
« Reply #7 on: August 13, 2011 - 11:32:22 PM »
ya i wasnt really thinking i was just venting cuz i was disappointed.
once it gets going its nice, but still miss that fun burnout
« Reply #8 on: August 14, 2011 - 12:19:17 AM »
Did you degree the cam in or just dot to dot on a timing chain ?   If the installed center isn't where it should be, it could be doggish on the bottom and wake up in the mid range.  Also, you said you changed the carb. Maybe it is not working well, or the timing isn't set right. A little 268 cam should roast tires when tuned right. You may be overlooking something
« Reply #9 on: August 14, 2011 - 07:16:34 AM »
Same cam, more or less, that's in my 318. Start with the tuning!
1976 Dodge Warlock
Offline joef89
  • 74 Challenger RT
« Reply #10 on: August 14, 2011 - 08:14:36 AM »
that was gona be our next step to degree the cam we just installed it dot to dot, and also the carb isnt the greatest i think the accelerator pump is starting to die. looking at getting a quick fuel 650 spread boar with mechanical secondaries
Offline Morris'_Mopars
« Reply #11 on: August 14, 2011 - 10:46:22 PM »
I second that!! If you dont have the correct stall speed you might be able to keep those rear tires from going up in smoke..
Morris' Mopars LLC
Raymond, Illinois
Mopar performance at affordable prices.
