Author Topic: rebuild kits for my 6 pack?  (Read 593 times)
Offline The4ork
« on: August 14, 2011 - 12:18:49 PM »
was thinking about getting this:
http://www.summitracing.com/parts/HLY-37-933/
but do i need 3 of them?
im assuming its enough to rebuild a std 4bbl and since i have 3 carbs ill need at least 2?
anyone have any suggestions? need to get something on order tonight so it ships early mon morning.
Re: rebuild kits for my 6 pack?
« Reply #1 on: August 14, 2011 - 01:48:43 PM »
There is a less expensive kit specifically for the 6 pack , it is around $28 each , you can often get away with two of those , even three is not overly expensive compared to that kit , I do not have the part # handy though .With that kit you should get both of the base gaskets needed & 2 of three needed float valves / needle & seat assy so two kits will get enough parts to do 3 carbs
Offline The4ork
« Reply #2 on: August 14, 2011 - 05:32:39 PM »
I also just found out my fed carbs float bowl hard thread that allows you to adj the float level :/
