not having done this yet it seems to be straight forward to a point , mount kits are available , small block transmissions bolt up although 518 requires the floor to be reworked for clearance in the T bar crossmember , I believe you have to run a different PCM , the factory one runs everything , you need to have one to control the engine or engine trans seperatly
