Author Topic: Will Not Idle  (Read 1342 times)
Offline polarbear123
Will Not Idle
« on: August 16, 2011 - 08:19:40 PM »
New 800 edelbrock carb on a 4 speed rebuilt 440. There are no vacuum lines and the vacuum ports are plugged the only line to carb is the hose from the pvc. After warming up and idling for10 minutes it will stall. Starts back up no problem and drives fine until you stop and will stall again. When it starts to stall I can pull pvc hose and it will keep running until I reattach hose.
Offline Strawdawg
    • Vortex Buicks
Re: Will Not Idle
« Reply #1 on: August 16, 2011 - 08:51:56 PM »
then, that sounds like it is flooding at idle...or on the verge of it.  Pulling the pcv line makes it go a lot leaner
Offline jimynick
Re: Will Not Idle
« Reply #2 on: August 16, 2011 - 09:01:57 PM »
Is there a regulator on it? Mechanical pump? Can you see fuel dribbling out the boosters when it's idling with the hose on? Try tapping on the carb body where the fuel line goes into it-gently. It may have a sticky needle/seat. Pressure shouldn't be more than approx. 7psi at the carb.  :2cents:
Re: Will Not Idle
« Reply #3 on: August 16, 2011 - 09:41:54 PM »
It is a Mechanical pump no regulator can not see any dribbling. it dose have a banjo fitting so it will clear air cleaner.
Re: Will Not Idle
« Reply #4 on: August 17, 2011 - 09:16:28 AM »
well I would remove the top of the carb & check the float level . they call for 7/16 , I usually set it a bit higher , , once you do that loosen the screw above the metering rods , move the plates over a bit & see if the rods stay down at idle in gear if auto  , if not you need lighter springs under the metering rods to keep it from flooding . I assume you have adjusted the idle screws so it idles as high as possible .
Re: Will Not Idle
« Reply #5 on: August 17, 2011 - 10:20:21 AM »
The idle screws were adjusted. I will give the rest a try.
Thanks
Re: Will Not Idle
« Reply #6 on: August 17, 2011 - 10:39:19 AM »
let me know
Re: Will Not Idle
« Reply #7 on: August 21, 2011 - 11:59:41 AM »
I tapped on the carb where the fuel line enters and drove it for 30 miles. It did not stall once. It is never that easy but it worked .
Thank You
