Author Topic: ported vacuum signal  (Read 567 times)
Offline CUDA JAS
  • vroooooom!
« on: August 16, 2011 - 09:59:59 PM »
The ported vacuum port on my holley 3310 (750 vac seconday) has a vacuum signal at idle.
Is this a sign that the throttle blades are open too far or a sign of something else?
Jason
74 'cuda 360/727
Just call me a gearhead!
Re: ported vacuum signal
« Reply #1 on: August 17, 2011 - 09:21:44 AM »
the only way to create ported vacuum is air flow though the venturi as it is above the throttle plates , at idle there should not be enough air flow to create vacuum in the venturi , could be an internal problem
