Author Topic: Pickup coil and reluctor parts/Misfiring problems  (Read 819 times)
Offline kitsapcuda
  • 1970 Plymouth Cuda
« on: August 17, 2011 - 11:22:37 PM »
I am currently having problems with my car misfiring and realized I have a piece missing off the pickup coil and reluctor, My main question is where exaclty does this piece go and would this affect the car, causing it to misfire. Thanks
Re: Pickup coil and reluctor parts/Misfiring problems
« Reply #1 on: August 18, 2011 - 02:03:00 AM »
no clue why that is in the picture , if the pick up has a yellow wire instead of orange the pick up may be bad , there are aftermarket ones with yellow wire that have caused me problems for a long time , second the gap between the 2 has to be .008 , too wide & it will misfire , three the reluctor has 2 key ways one for clockwise & one for Counter clockwise there is an arrow by one keyway , if it is not right you will have problems . Next check the ground for the ECU , it has to be clean  tight , could also be a bad ECU
Offline Strawdawg
    • Vortex Buicks
« Reply #2 on: August 18, 2011 - 09:16:16 AM »
So I now know why there are two key ways...made me wonder ever time I pulled it off... :dogpile:
