Author Topic: Intake leak  (Read 500 times)
Offline shatar4
  • 71 Challenger
Intake leak
« on: August 18, 2011 - 10:17:07 AM »
I have a new intake that I'm put on my 340 and it seems I have a leak in the two back cooling ports. I know there is ports in the intake but not on the stock heads. What can I do to seal these off so I don't get anti-freeze everywhere? Thanks
1971 Triple black 340 Challenger
Offline Strawdawg
    • Vortex Buicks
Re: Intake leak
« Reply #1 on: August 18, 2011 - 06:59:40 PM »
take the intake off and seal the ports with some silicone on the various mating surfaces-water ports
Offline jimynick
Re: Intake leak
« Reply #2 on: August 18, 2011 - 07:21:48 PM »
 :iagree:. Some of the old-school boys used a piece of thin (.010") brass shim stock cut to cover the port to go along with that silicone. When you've got the intake off, check on a piece of plate glass to make sure it's flat. Any more than about .002" (use a feeler gauge) discrepancy might require a trip to the machinist to level 'er off. Some times, a thicker gasket can be gotten away with.  :2cents:
