hey guys, i recently just purchased my cuda and unfortunately have not driven it yet. i thought i was having carb issues and went to switch the 6 pack manifold to a 4bbl air gap. with the manifold off i found some frightenting issues!
my far aft passenger side rocker arm was loose, since the cam and lifter had aparetnly ate itself apart. this is the aar cuda engine. 340 with J 360 heads, and adj rockers.
i have a set of mechanical lifters and pushrods, new in box i can install. i also have a mechanical cam. suposedly this cam used to be in this engine according to the PO but hes a knucklhead and anything he says could be way off.
the cam is a Erson Hi Flow 1M and there is also a 589 stamping on it. the cam i HAD was a sum-6901 276/286, Lift .441/.441
now i'd like a slightly hot cam that makes good power up top without killing the bottom end. a good mid-range cam would be good with decent flow up top and below. if that makes any sense. but i also am going to be daily driving the car so anything too hot will kill my mpg's to a point i cant afford to feed it.
so im looking for reccomendations.
throw in the solid lifter stuff and X cam?
buy all new hyd stuff since i dont want a too hot of cam and dont need it? and a new hyd cam?
throw in what i got today and run it anyways bc i could always change it later if i dont like it....
cam:
