Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Suspension, Wheels/Tires, and Brakes
(Moderator:
Chryco Psycho
Brake fluid capacity from empty
« previous
next »
Print
Pages: [
1
Author
Topic: Brake fluid capacity from empty (Read 549 times)
lime73
Jr. Member
on:
August 20, 2011 - 01:31:46 PM »
What is the brake fluid capacity from empty? I just finished replacing everything and need to fill from dry and need to know how much to buy. Also what DOT does everyone recommend?
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re: Brake fluid capacity from empty
Reply #1 on:
August 20, 2011 - 01:46:53 PM »
approx 1 lt/ qt , by the time you bleed the master & all the lines & waste some of it .
I use Dot 5 as it will not hurt the paint , you should not mix with Dot 3or4 but if everything is new no problem
Logged
burdar
Sr. Resident
Reply #2 on:
June 04, 2012 - 09:41:57 PM »
Reviving an older thread here...
Brake fluid capacity is probably different depending on if the car has front discs or not. The OP never stated what he had. So, was one quart enough? I'm going with DOT5 and at $24 per quart, I don't want to buy a second bottle if I don't need it. This is for front discs and 10" rear drums.
Logged
edl94
Jr. Member
She Cuda
Reply #3 on:
June 04, 2012 - 10:02:34 PM »
I used dot 5 and it was less than a quart. All new stuff master cyl, front calipers, and rear wheel cyls, and soft lines. Steel lines were drained and blown out with air. Mine blead out fast but a quart should be more than enough.
Logged
burdar
Sr. Resident
Reply #4 on:
June 04, 2012 - 10:53:24 PM »
Awsome...thanks!
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
