Author Topic: Metering Valve Question  (Read 3021 times)
Offline EB3-GranCoupe
  • BP23 U0B
« on: August 20, 2011 - 06:35:47 PM »
Is there some one here who can help me with understanding how a Metering Valve works?
http://www.yearone.com/yodnn/TechFAQ/WheelsTiresBrakesFAQ/MoparBrakeLinesValves/tabid/422/Default.aspx
Mine is leaking (brand new from InlineTube) down at the valve stem.  I don't know if it is defective, or if something needs to be undone and re-tightened.
Thanks for any responses!
Offline Strawdawg
    • Vortex Buicks
Re: Metering Valve Question
« Reply #1 on: August 21, 2011 - 09:32:20 AM »
from the number of posts on this subject and the inline replacements, I guess yours is par for the course.  I think some have had luck taking them apart and replacing the cracked o-rings in them.   At least luck in stopping the leaks
  • BP23 U0B
« Reply #2 on: August 22, 2011 - 08:03:01 AM »
i did search the posts, but didn't find much specific to metering (or hold-off) valves.  i did run across a link that led to another link and found this:
http://www.imperialclub.com/Repair/Lit/Master/257/page08.htm
I will be calling Inlinetube today, and see what they say.
Offline spamtank
« Reply #3 on: August 22, 2011 - 06:32:15 PM »
I purchased the proportioning valve along with the hold off valve from In-Line.  I ended up only installing the hold off valve.  Knock on wood, mine is not leaking.  I suppose I lucked out.
I hope you are able to get things worked out there.  Nothing worse than leaking brake fluid all over everything.  :stomp:
Rick, Manchester, NH
1970 SE 383 2V AT Challenger
1977 M882/W200 Power Wagon
2013 RT Plus 6M
  • BP23 U0B
« Reply #4 on: August 23, 2011 - 07:12:50 AM »
Quote
I used DOT-5 brake fluid, or else i would have no paint whatsoever!  I called inlinetube, and reported the defective valve.  even though i have only 38 miles on it since installation (kinda hard to drive when the front brakes aren't grabbing), they only warrant it 6 months from the time of purchase, which was june of last year.  so they gave me a discount on a new one.  chalk it up to the cost of having a hobby!
The Imperial Club website has some really good technical articles.  i had no clue what a 'metering valve' did, or how it works.  now it makes sense!
Offline spamtank
« Reply #5 on: August 23, 2011 - 07:51:12 PM »
I installed the Inline proportioning valve, but had trouble bleeding the rear brakes.  After cleaning up the original, and reinstalling, they bled fine.  I tried to return it, but they declined my request.  As you said, "cost of having a hobby."  I couldn't find the "center the valve" procedure.  That probably would have worked. :banghead:
Quote
That is a great site.   :worshippy  Thanks for that! :thumbsup:
2013 RT Plus 6M
  • BP23 U0B
« Reply #6 on: August 25, 2011 - 07:31:52 PM »
My replacement metering valve arrived today.  i know where i will be saturday morning!!!
Offline spamtank
« Reply #7 on: August 25, 2011 - 07:41:09 PM »
Are you going to take the leaking one apart to trouble shoot it?  I'd be curious to know if it was a cut o-ring like I've read about on another page.  Good luck! :popcorn:
2013 RT Plus 6M
  • BP23 U0B
« Reply #8 on: August 26, 2011 - 01:04:01 PM »
yes, you read my mind.  if i can remember to grab the camera, i'll try to take some pics too.
  • BP23 U0B
« Reply #9 on: August 27, 2011 - 04:48:19 PM »
Got started at 8am, and removed the leaky valve, and installed the new one.  made sure i had no line leaks, and bled the front brakes.  It seemed like i still had some air, so bled them again, and got some air bubbles to release.  unfortunately, i forgot to check the resevoir, and ran the master cylinder dry  :banghead:
filled it up, ran thru the whole bleed thing, again.  and the new valve started leaking.   :villagers:
gave it up as a bad job, parked the car, and mowed the grass,  i needed to get something accomplished correctly!
so after mowing, and a few honey-do's; i took the first one apart:
Intake port on the top, left front brake exits on the left & right brake on the right:
from the other side (thats the intake port on the left):
rubber dust seal:
without the dust seal:
unscrewed the hold in assembly:
the diaphragm assembly:
Looking down into the valve:
the rubber valve seat:
Everything seemed to appear ok.  no torn pieces, nothing out of the ordinary.  Being a brand new machined part, i wonder if maybe it got stuck in the open position??
« Last Edit: August 27, 2011 - 04:58:43 PM by EB3-GranCoupe »
Offline spamtank
« Reply #10 on: August 27, 2011 - 06:36:56 PM »
I looked at the photos, and added a few comments.  You did get really good pictures of all the parts.  Even so, it's sometimes hard to see what's going on.
2013 RT Plus 6M
  • BP23 U0B
« Reply #11 on: August 31, 2011 - 12:59:25 PM »
Spam,
Thanks for the feedback!  As to your observations:
Bore condition - I didn't run my finger in it, but it appeared that the dark colorign is due to the rubber seal at the bottom of the spring.
Ragged edge of seal - Hmm, i'll take it apart again, and look at it closer.  i didn't notice that.
Knurled edge - yes, i noticed that too, as soon as i unscrewed it.  it did take some effort to get it loose.
It may be a while before i can get it apart again.  the next several weekends are already planned out.  thanks again!
