Author Topic: 340 stroker kits  (Read 5055 times)
Offline shatar4
  • 71 Challenger
340 stroker kits
« on: August 20, 2011 - 08:37:23 PM »
Since the cruising season is almost over, I am going to have my 71 340 rebuilt and after reading some posts on here I've decided to stroke it. It's a 71 motor that's already .40 over. What I'm looking for is the best stroker kits that are available out there. thanks.
1971 Triple black 340 Challenger
Offline ChallengerHK
Re: 340 stroker kits
« Reply #1 on: August 20, 2011 - 10:31:19 PM »
 :popcorn:
- Han Solo, Star Wars
« Reply #2 on: August 20, 2011 - 11:28:03 PM »
Not sure who makes the best kit for the small block .You can call my machinist Barry @ 403-340-1744  he can let you know what works he often answers the phone on Sundays & evenings
Offline jvike
  • Pro-Touring Cuda
« Reply #3 on: August 21, 2011 - 05:35:54 PM »
I think the fully balanced kits that Mancini racing sells looks good, Callies forged crank, forged diamond pistons, H-beam rods.
« Reply #4 on: August 21, 2011 - 05:46:35 PM »
Muscle Motors will have kits as well
Offline Skeleton73
  • Rattling glass once again
« Reply #5 on: August 25, 2011 - 09:39:44 PM »
I went with a forged Scat kit on the reccomendation of my engine builder. I think Hughes Engines carries & sells them.
Iread a bunch of threads here first. Search enginee builders or stroker kit on the site, and you should find some good info.
Offline kielbasa
« Reply #6 on: August 29, 2011 - 10:49:51 AM »
hard to beat  BPE - i got his 4.125 forged crank, 6.2 compstar rods and matching forged pistons for a great price, it was a no brainer when i was shopping around.
Offline the_engineers
« Reply #7 on: August 29, 2011 - 06:01:46 PM »
BPE = Bouchillon Performance?
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
Offline Jim
« Reply #8 on: August 29, 2011 - 10:58:08 PM »
Not the best starting point for a stroker motor, or any rebuild for that matter. Get it sonic checked before buying any parts. Unless it checks out exceptionally thick (not something 340s are known for... quite the opposite actually) and/or cleans up with nothing more than honing, you'll probably want to start with a standard bore block. And if you go hunting for a block, STD 360s are far less expensive than 340s. Sleeving is another option, but that gets expensive quick.
Need to decide how fast you want to go. Generally consensus is that cast cranks and I-beam rods are fine up to 500 hp or better (assuming quality machine work, balancing and assembly).
Exception would be Eagle cast cranks. Lot's of documented issues.
CNC Motorsports has good deals on stroker kits. Unless you're building it yourself, consult with your machine shop.
-Jim
"Relax, all right? My old man is a television repairman, he's got this ultimate set of tools. I can fix it. "
Offline kielbasa
« Reply #9 on: August 30, 2011 - 10:36:26 AM »
BPE = Bloomer Performance Engineering............get a hold of him (easy on Moparts).....check out his products and pricing and you'll be hard pressed to beat it. Actually a thread there (and  for A bodies only) on a 430" build using his rotating components.
Offline ragtopdodge
« Reply #10 on: August 30, 2011 - 11:31:33 AM »
'70 318-auto Chally 'vert
06 300c SRT8
04 2500 QCLB 4x4 HO
