Author Topic: transmission fluid question  (Read 961 times)
Offline lime73
« on: August 21, 2011 - 11:16:04 AM »
What is the best transmission fluid to use for a 727 after a complete rebuilt?  Built to stock specs with a B&M shift improver kit.   How does everyone feel about using generic store brand lubricants?  I was once told by a parts supplier that most store brand oils are provided by the brand name oil companies.
Re: transmission fluid question
« Reply #1 on: August 21, 2011 - 11:54:36 AM »
Years ago the best solution was to use F type fluid but the key was to never mix with regular ATF
For the cost of rebuilding a trans I would use the best fluid possible , saving a few $$ & having to pull the trans & rebuild again makes no sense to me .
 Things have changed & I do not know what the best fluid to use now is , Terry can help you with this , F type seems to have disappeared since all the synthetics have come into play . the other issue is you change engine oil every 300 miles or so but never think about the trans running 50,000 miles on it .
 I agree that most generic oils are made by major oil companies but not nessisarily with the same additives
Offline mach3107
« Reply #2 on: September 10, 2011 - 02:47:13 AM »
what fluid would you recommend for a used 727. Got it from a 77 truck(shifted good before truck was scraped). I'm changing the filter and fluid now.
« Reply #3 on: September 10, 2011 - 09:28:22 AM »
Dexron 3 or 4
