I took the time a several years ago to get the biggest tire possible in an ebody without fully tubbing it using stock wheelwells!
I had the rear custom cut to 54 5/8(b body is 55" and 44" centers on the perches) and use the dr diff 1" relo kit! 15*10 rims with 5" backspace! I had no rubs whatsoever! I did roll the outter top part of the lip which is easy to do even with the car painted! believe my perches were centered at 44" or maybe a hair less like 43.75" ! I believe my setup was 3" drums on that...
I got 315/60/15 ET street radial in there (which is 13.5" total width) an no rubbing at all
the pic below is a 29.5/10.5 slick!
You need to factor in for what type of brakes used - discs/2" or 3" wide drums! basically just buy a set of wheels you like first in 15*10 with 5" backsapce and set them in the wheelwells! I dropped a plumbob on each side fromt he frame rails and moved the tires to where I felt comfortable it wouldnt rub which was about 1/2" on each side (make sure tires have full air pressure in them for measuring) Prop the tires up to ride height you like also using blocks of wood or whatever!
Once that is done take a tape measure and measure from rim mounting flange to the other rim mounting flange! THIS IS YOUR MAGIC NUMBER TO START BY! after that its math! You can buy new moser ends for about $85
example: your rim flange to rim flange was 60.5" your using drums that are 3" wide total!(*2) 60.5-6 is 54.5" have the machine shop or yourself cut tubes and weld on the moser ends to where the total housing flange to flange is 54.5" (outside edges) and tell them how to offset the tubes...
After that is all said and done and your ready put the rear in the with springs etc... Now dont weld your new perches just set them in and just snug up u bolts on to make sure you can roll the rear so you have proper pinion angle and will get your perches exactly where they need to be on the housing also! get the car on its suspsension ( I use car ramps to get under there easily and be careful cause you have no driveshaft in there to lock the car, I stagger the ramps in different directions)
PINON ANGLE! now that is all done measure off the back of your tranny and measure off the yoke on the rear! add these 2 numbers together and that is your pinion angle!
example: tranny is -2 down roll the pinion down to -1* to -2* down which gives you -3/-4 total pinon angle which is good for a caltrac type setup! and then tack the perches in then fully weld but box the perches in with the caltracs for strength which is just a flat plate cut to the dimension of the perch and housing opening there! you also do not need to use a pinion snubber with caltracs
Superstock / Stock type springs example: Do same as above but lets say tranny is -3* down so roll your rear down -2 to -4* and tack in ! most like -5* to -7* pinon angle for that spring setup!
Now if your using a TALL tire setup and like to go to the track the rear will roll forward some and I suggest atleast 5/8" clearance to the front of the wheel well lip! Cause when you launch the tire will grab and pull all the paint off or worse.... Here are a few ways to move the rear back!
1. Weld the holes shut on the perches and drill a hole further back some to where needed!
2. Offset lowering block which is just a block with a hole in it and a pin moved back!
3. Cut some plates the thickness you need and place them in front of the front spring hanger and body you may only need 1/8"...
you can do same as above for low profile type rim and tire setups also! Hope that all made sense and I didnt forget anything
I used all the steps above for my dart also..
