70 Barracuda headliner bows.
Author Topic: 70 Barracuda headliner bows.  (Read 4000 times)
Offline Dark Horse
  • 70 Cuda ,69Mach 1,70 Charger RT/SE
« on: May 09, 2002 - 09:00:31 PM »
I got the bows they came with the car,not on the car!The ends are color coded,does anyone know the order of placement or does it not matter????
« Last Edit: December 31, 1969 - 07:00:00 PM by 1023595200 »
When you see the Dark Horse...take heed
hell is coming to breakfast......
Offline camjam
  • Rare-it-T
Re: 70 Barracuda headliner bows.
« Reply #1 on: May 09, 2002 - 11:37:08 PM »
It does matter. Unfortunately I can't remember what went where. Its been a couple of years since I replaced them.
71 Challenger R/T 383 4spd - 1 of 10 known to have been built for canada - restored
70 Charger R/T SE 440 auto - restored
Offline Dark Horse
« Reply #2 on: May 10, 2002 - 01:18:17 AM »
ok,thanks camjam, if you remember please let me know. :)
Offline Grrreen
  • It's Bug Guts Grrreen!!
    • Media Dog Productions
« Reply #3 on: May 12, 2002 - 11:48:22 PM »
When I did the headliner on my 70 Challenger, the bows were NOT colour coded... They were all red on the ends.
I fortunately had the opportunity to number mine as they came out, so I put them back in the same way.
However, everything that I have read says that some of the bows can be swapped.  But, it is not recommended with used bows as they typically have formed to the position they were in for the last 30+ years.  If your bows are used you may just want to install them without a headliner and try to see where they seem to fit the best.
Also, when you do eventually install the headliner don't forget that the last bow closest to the rear window typically has two small wires that hook around the bow and clip into the actual roof of the car just above the rear window.  These are used to pull the headliner back and help to keep it taut from front to back.
Also, *clean everything*, and use lots of spray adhesive along the sides where there are no "teeth" to hold the material.  You will be glad you did when your headliner turns out wrinkle free.  ;)
