Author Topic: Custom fuel line setup  (Read 506 times)
Offline lime73
« on: August 25, 2011 - 10:18:22 AM »
Pictures of custom fuel line setup.  Tried to make look as factory as possible.  My neighbor is a Master with the tubing bender.  Does that distributor placement look right.  Should the vacuum advance line be rotated 1/8th turn towards carb?
« Last Edit: August 25, 2011 - 10:27:53 AM by lime73 »
Re: Custom fuel line setup
« Reply #1 on: August 25, 2011 - 11:44:53 AM »
I usually have it positioned 1 tooth back towards the carb
Offline GoodysGotaCuda
« Reply #2 on: August 25, 2011 - 12:40:23 PM »
If it's aluminum line I'd consider adding a bracket to help keep the weight off the hardline (cracking). If it's steel it'll probably be fine. Looks good  :2thumbs:
1976 Dodge Warlock
Wheel & Tire Specs:Link
