Author Topic: 727 trans cooler line pressures  (Read 1975 times)
Offline e-chal
« on: August 26, 2011 - 01:17:25 PM »
How much pressure is typically found in the trans cooler lines running to the radiator oil cooler, especially the trans outlet line pressure?
Re: 727 trans cooler line pressures
« Reply #1 on: August 26, 2011 - 04:57:34 PM »
I think it is around 30 PSi , not excessively high
Offline e-chal
« Reply #2 on: August 26, 2011 - 06:19:11 PM »
Thanks Chryco for reply. Just trying to decide whether to use an-type fittings or hose barbs for running some tubing.
« Reply #3 on: August 26, 2011 - 08:05:55 PM »
anything you can do with AN you can do with the Cheaper Steel fittings Jic type fittings , it would be better done with proper fittings over just using barbs & I am sure you could by all the steel fittings for about $15 !! Barb fitting with simple worm gear clamps work just fine as well just use a high quality hose for trans lines .
« Last Edit: August 26, 2011 - 08:09:33 PM by Chryco Psycho »
Offline e-chal
« Reply #4 on: August 27, 2011 - 12:30:46 PM »
Sorry about slow response as I got busy. Your post sure gives me a clearer picture of what I can do so thanks for the help.
