Author Topic: 8 3\4 Rear width...  (Read 985 times)
Offline DodgeFreak
  • Cars and trucks are my friends..
8 3\4 Rear width...
« on: January 06, 2005 - 08:15:17 AM »
I got an 8 3\4 rearend for free out of a Coronet its a posi but i don't knw the gears but my question is...how wide is it?? i'm thinking about shoving it under my duster and runnin of set rims if its only an inch or two wider...and i'm not going to shorten it..thanks.
74 Plymouth Duster- restoring
77 Dodge D150 shortbox- as long as i don't change my mind will be a step side dually diesel or a 383 powered truck
04 durango 4.7
Re: 8 3\4 Rear width...
« Reply #1 on: January 06, 2005 - 11:46:45 AM »
The 66-70 Coronet is close , use the offset rear hangars & it will bolt in , the reart is just slightly wider than the A body diff http://www.mymopar.com/axledims.htm
Offline DodgeFreak
« Reply #2 on: January 06, 2005 - 08:27:37 PM »
Where could i get a set of rear off set hangers??
04 durango 4.7
« Reply #3 on: January 06, 2005 - 09:23:11 PM »
Mopar  P4120075
