If your tach does not work, you can use a voltmeter to find out if the problem is in the wiring or inside the tach.
First, start the car and let it run. Next, take a voltmeter on the DC 20V setting and measure the voltage on the long stud on the back of the tach (making sure
the black wire on the voltmeter is well grounded to the car). You should see 12V (13.5 is OK) on the long stud. If it reads 0V, then you are
not getting 12V to power the tach and you need to fix the wiring harness or fuses.
On the short stud, on the 20V DC setting, you should see something between 3V and 6V or so. If it reads 0V then the problem is that the signal is not getting from the
minus side of the coil to the short stud. Fix the wiring harness.
If both of these signals are present at the back of the tach, and the tach is properly grounded, then the tach itself is probably bad.
You can either send it out to have it repaired, or you can purchase my tach repair kit and fix it yourself. See my website for more information:
www.rt-eng.comGregGarner
www.rt-eng.comHome of the Mopar clock and tach repair kit
