Author Topic: Hypothetical engine build - cam and converter question  (Read 4585 times)
Offline CUDA JAS
  • vroooooom!
« on: August 28, 2011 - 09:03:02 PM »
What cam and convertor would you use (and why) if you were building a 360 engine with the following specs:
9:1 compression;
stock heads (good valve job but no porting);
edelbrock performer RPM intake; and
750 holley (vac secondary) carb.
The engine would be in a 74 cuda, with a 3:23 gears (28 inch tires).
the car would be used 100% on the street, crusing with the family and for trips out of town.
Just spit-balling ideas for a wither project.  :dunno:
Jason
« Last Edit: August 29, 2011 - 09:19:27 PM by CUDA JAS »
74 'cuda 360/727
Just call me a gearhead!
Offline PlumCraZRT
Re: Hypothetical engine build - cam and converter question
« Reply #1 on: August 29, 2011 - 03:29:31 AM »
For dragging kids around?  A comp 268H hydraulic flat tappet cam and a 1500-2000 rpm converter.  It would start easily, run no problem.  Give you good, low torque for driving around town.  Reliable all day for driving the fam around.
Better question is why you want to put a 750 cfm carb on top of a 383 with stock heads?
mmmmm.... Mopar.... *drool*
Offline Cooter
    • christinecarclub.com
« Reply #2 on: August 29, 2011 - 06:29:18 AM »
Even better question would be where do you see it's a 383 engine?
Offline GoodysGotaCuda
« Reply #3 on: August 29, 2011 - 09:04:55 AM »
 :worshippy
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline Strawdawg
    • Vortex Buicks
« Reply #4 on: August 29, 2011 - 10:07:45 AM »
http://www.lunatipower.com/Product.aspx?id=1544&gid=287
should be a great match with a stock converter, or up to 2200 or so.
« Reply #5 on: August 29, 2011 - 10:16:06 AM »
If you want a hyd I would use the Lunati 303 VooDoo matched with a 2400 stall
Offline PlumCraZRT
« Reply #6 on: August 29, 2011 - 04:52:40 PM »
What do we assume then?  Sounded like a car that would come with a 383.
Offline Strawdawg
    • Vortex Buicks
« Reply #7 on: August 29, 2011 - 06:31:10 PM »
If we assume his signature to be correct, then it would appear that a 360 is the correct assumption.  If he is building a new engine from scratch...then your assumption is as good as anyones
Offline CUDA JAS
  • vroooooom!
« Reply #8 on: August 29, 2011 - 09:21:10 PM »
oh @%!# :screwy:
Sorry about that, yes I am running a 360.  Sorry I fixed it.
74 'cuda 360/727
Offline Strawdawg
    • Vortex Buicks
« Reply #9 on: August 30, 2011 - 10:38:42 AM »
Ok, now that we all know it is a 360, I stick with the cam I linked above....for a 3.23 with taller tires which further reduce the gearing a bit, it should be a good, flat torque curve that works for cruising, and normal street driving.  If it was a bigger inch engine, or lower geared, I would choose the next cam up which is 268 at .050".
This one should work perfectly with 9-1 compression and your combo, imo :)
Offline PlumCraZRT
« Reply #10 on: August 30, 2011 - 11:21:55 AM »
I would still say that since you plan on using unported stock heads, a 750 cfm carb is overboard for street use.  The ride would be much more street friendly with a 650/670 cfm carb.
You aren't planning on super/turbocharging it, are you?  Is the long block already together?
« Reply #11 on: August 30, 2011 - 05:05:07 PM »
If you just want a nice street machine, and aren't trying to get the most out of it...By all means look at a smaller carb.
Offline Strawdawg
    • Vortex Buicks
« Reply #12 on: August 30, 2011 - 06:03:08 PM »
use a vacuum secondary carb and eliminate the problem of size
Offline CUDA JAS
  • vroooooom!
« Reply #13 on: August 30, 2011 - 11:49:21 PM »
Uhhh, no, no plans to super / turbocharged the engine.
Oh yeah the long block is together, hell its in my car runing today.
I am currently runing the following cam:
@050 Int dur. 222 , Ex dur. 234
Lift Int .447 Ex .450
Intake Centre line 107 Ex centerline 116.
The engine works, I have tuned the carb so there is no bog, but it is still not stong under 2500 rpm.  It is better withe RPM intale as opposed to the Torker II intake I had on last summer.
After a charity rally, around town over the weekend, I realized how bad the cam is for around town.  So I am just spit balling ideas for a possible winter cam change.
Thanks fro the input.
Jason
74 'cuda 360/727
Offline PlumCraZRT
« Reply #14 on: August 31, 2011 - 11:24:40 AM »
You got an automatic or a manual behind it?
