Author Topic: Windshield wipers parking problem  (Read 10855 times)
Offline LukeSkywalker
  • Plymouth
« on: August 30, 2011 - 01:51:33 PM »
My wipers still try to park in the middle of the windshield. 3 speed switch and motor. Everything else seem ok.
Tried grounding motor and switch, but no difference. Any advise on what might cause this..?
Offline passion4mopars
    • Passion4mopars
Re: Windshield wipers parking problem
« Reply #1 on: August 30, 2011 - 01:56:23 PM »
Can you take a photo of the switch plate timing and post it?  Sounds to me like the timing on the switch plate is incorrect
Offline JayBee
« Reply #2 on: August 30, 2011 - 04:34:07 PM »
Kim's probably right.   Just thought I'd post a pic of the position of my switch plate/timing thingy.
John
1970 Barracuda convertible
2014 Toyota Avalon
    • Passion4mopars
« Reply #3 on: August 30, 2011 - 05:42:44 PM »
I edited John's photo showing the timing nib locations for both E body applications and B Body applications...thanks for the great photo John and that motor is timed correctly    :bigsmile:
Offline JayBee
« Reply #4 on: August 31, 2011 - 07:41:21 AM »
Thanks for editting my picture Kim and confirmation on it's timing "nib". I was wondering what to call that thing instead of a "thingy".
John
2014 Toyota Avalon
    • Passion4mopars
« Reply #5 on: August 31, 2011 - 07:56:51 AM »
For lack of a better word and rambling through thoughts on the phone with someone now and again I've been known to call it a "tit"....aghghggh but it is something we all understand right?  LOL
Offline Slotts
« Reply #6 on: August 31, 2011 - 08:22:00 AM »
Slotts
  • Plymouth
« Reply #7 on: August 31, 2011 - 12:55:42 PM »
Click here to view a bigger wipermotor picture
The wires look bad but are all ok. Nothing touches ground, just looks like it does..
How do I adjust timing on switch plate?
« Last Edit: August 31, 2011 - 12:59:53 PM by LukeSkywalker »
    • Passion4mopars
« Reply #8 on: August 31, 2011 - 12:58:41 PM »
Real hard to tell from the photo but it looks like it's timed properly....next question, part number on the crank arm.....what's the part number on the motor?
Wanna give me a call?  865-365-5833   Let's see if we can walk through this?
    • Passion4mopars
« Reply #9 on: August 31, 2011 - 02:26:02 PM »
You can loosen the screws holding the switch plate to a point where you can lift and turn it, but yours looks like it's timed correctly....have you done a 2 to 3 speed conversion?  Replaced the crank arm?  Driver's side pivot or anything else been modified?
« Last Edit: August 31, 2011 - 02:28:11 PM by passion4mopars »
  • Plymouth
« Reply #10 on: August 31, 2011 - 02:51:03 PM »
I don't know what's been done to it other than what I did, and that was to change from a 2 speed switch to a 3 speed..
With the 2 speed switch it wouldn't attempt to park at all. Went from bottom to top of windshield, and when turned off it parked at bottom of windshield - did not attempt to go further down.
I'll take the grille off the top and take a picture and see if I can find a number on motor and arm.
Is the link between the long crank arm and the motor possible to mount wrong?
Doubt a phonecall would do any good, as my terminology suck in writing and is even worse performed vocally...
I might be able to film it running and youtube it.
« Last Edit: August 31, 2011 - 02:56:56 PM by LukeSkywalker »
    • Passion4mopars
« Reply #11 on: August 31, 2011 - 03:28:06 PM »
 :roflsmiley:  You're talking to a blonde....if you speak blondinese we'll do fine  LOL
Here's the part numbers you want to make sure that you have with your 3 speed motor:
wiper motor crank  part #2822289-(70-71)
link from the motor to the driver's side pivot  part #2822293(70-71)
Variable speed switch
The crank arm part number, of course, is going to be on the side mounted closest to the wiper motor
This post has photos of the E body wiper motor transmission assembly, it might help you
http://passion4mopars-moparbodystyles.blogspot.com/2011/06/1970-e-body-wiper-transmission-restored.html
  • Plymouth
« Reply #12 on: August 31, 2011 - 03:39:20 PM »
Thank you, that helps !
I do remember the small arm on the motors position when parked. Its facing the driverside.
    • Passion4mopars
« Reply #13 on: August 31, 2011 - 03:43:04 PM »
When it's parked it should be parallel with the cylinder of the motor.  I'll put a crank arm on the next motor up on my bench and shoot a photo of it in the parked position if you want me to, but it should be parallel when parked
  • Plymouth
« Reply #14 on: August 31, 2011 - 03:59:12 PM »
n
Then I think it's in the right position as it stands. I'll check the partnumbers.
