Author Topic: Mopar Action Magazine  (Read 2271 times)
Offline BadJoey
« on: August 30, 2011 - 06:01:54 PM »
Has anyone here got their new issue yet . What has my attention is Prime Steer on page 60 . I,m wondering what you guys think ? I've been having other issues with my steering and have noticed symptoms in this article .I went to the suggested web site but the kit is not there or ready for sale for E bodies yet . I called feelFirm and they said about 3 or 4 weeks and a cost of $125 or $150 . I know others who have the same gripe about sloppy steering and this "sounds" like a fast easy fix . Thoughts ? :clueless:
« Last Edit: August 30, 2011 - 08:22:41 PM by BadJoey »
Offline mopar12372
    • mopartech
Re: Mopar Action Magazine
« Reply #1 on: August 30, 2011 - 07:23:43 PM »
what is replaced ?
RESTO PICTURES
Offline BadJoey
« Reply #2 on: August 30, 2011 - 08:30:17 PM »
what is replaced ?
In a nut shell it says the pitman arm is too long . With someone else working my steering wheel back and forth you can see my gear box move , same as in the article . They say that = sloppy steering . The solution is a plate with a bearing that bolts to the k frame and the out shaft of the gear box stiffining everything up . It's a good read with plenty of pitchers just wish I knew if it worked or not . If I get no bad feed back it will make for an easy winter project .  :dunno:
Tried to scan it so I could post it for you folks but it came out too fuzzy . I probably could get in trouble for that anyway . (copy wright)
« Last Edit: September 01, 2011 - 08:20:08 PM by BadJoey »
Offline mopar12372
    • mopartech
« Reply #3 on: August 30, 2011 - 08:33:05 PM »
i would get one if it worked . thanks for the information , it this month ?
RESTO PICTURES
Offline RB2929
« Reply #4 on: August 31, 2011 - 04:33:49 PM »
Read the article today. Firm Feel, $125-$150?  I figured the piece would cost around $50-$75.  Guess I'm wrong (again).  Another suspension/steering piece to be revealedin next Mopar Action.
« Reply #5 on: August 31, 2011 - 05:15:10 PM »
I haven't seen it yet but...the steering box mount has always been a flex point in the system. Gussets to shore up the mount and reduce deflection have long been a standard for improved handling to those in the know, so the thought that the steering output shaft is too long and allows flex seems almost like a band-aid fix to a practically non-existent problem, IMO. However, if it is a simple bolt in, then maybe it has some merit compared to yanking your engine out and welding up gussets to the steering box mount, and at $150, they will still sell plenty because the cheap way out is also the mucho harder way to fix the issue.
Offline BadJoey
« Reply #6 on: August 31, 2011 - 08:13:52 PM »
I was thinking the price was a little high . But I was also thinking Rack and Pinion before reading this . I tightened the free play out of the box which did help however the car still seems to want to drift . I'm NOT saying this will be a fix but if it was and the parts were quality the price could be worth it .
Offline the_engineers
« Reply #7 on: August 31, 2011 - 11:25:01 PM »
Keep us posted. I hate the way they write so much that I won't waste my money on it. Their crap was funny when I was 15, but not 20+ years later...
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
Offline wally426ci
    • maryland mopars
« Reply #8 on: September 01, 2011 - 06:57:56 AM »
Im interested in this also, curious.
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline shadango
« Reply #9 on: September 01, 2011 - 08:58:55 AM »
I saw that too and was wondering if its worth it.  I have a FF level 3 and while steering isnt what I would call "sloppy", I might try it for the price and see what the improvement is.
I dont think they are available yet though....
Offline cudagirl4406pk
    • Garageartmusclecars
« Reply #10 on: September 01, 2011 - 07:17:02 PM »
I had firm feel rebuild my unit with a level 3 and it is awesome steers like a new car i would recommend that to you.
michele
Offline Travis72
« Reply #11 on: September 13, 2011 - 02:09:40 PM »
I have one of the DSS steering stabilizers on my Gen 2 Ram truck and it did make a big difference.  They based the Mopar kit off of the DSS, so it seems like it should help?  :dunno:
Travis
72 Cuda
