Author Topic: 1978 dodge truck engine id 318 or 360  (Read 3373 times)
Offline WVUFELLA
  • (OO/---------\OO) closest i could for a 72
« on: September 01, 2011 - 09:23:11 PM »
hey guys i jus bought a 78 dodge truck ... th window sticker said it had a 360 but i dont knwo if it is still in thee... how can I identify what engine is inside????? without disassembling....
Offline 72cudamaan
Re: 1978 dodge truck engine id 318 or 360
« Reply #1 on: September 01, 2011 - 09:36:50 PM »
casting # on the side of the block.
If I cant fix it, it's broke
Andy  (phukker whither)
Offline WVUFELLA
« Reply #2 on: September 01, 2011 - 09:43:14 PM »
on passenger side or driver side????
Offline GoodysGotaCuda
« Reply #3 on: September 01, 2011 - 09:53:19 PM »
I believe it's drivers side. It will clearly say "318" or "360" in ~3/4" tall numbers
1976 Dodge Warlock
Wheel & Tire Specs:Link
« Reply #4 on: September 01, 2011 - 10:33:44 PM »
if you scrape below the left cylinder head , the # will be stamped on the block
 is it a hooley or carter carb , holley was 360 but the intak ecould have been swapped
Offline Aussie Challenger
« Reply #5 on: September 02, 2011 - 09:28:13 AM »
There is a long raised casting number above the starter motor and in the middle it will have ### 318 ### or ### 360 ###, it can get a bit oily and dirty so you might have to scrape the crud off.   :thumbsup:
Offline WVUFELLA
« Reply #6 on: September 02, 2011 - 12:18:57 PM »
Sweet found it ..... sure enough 360... thanks guys/gals
