Author Topic: How and where to locate the Temp. and Defrost/heat cables under the dash?  (Read 872 times)
Offline Chlngrcrzy
Where do the temp control, and defrost/heat cables route under the dash? part of the clutch pedal comes up and hits the cable or the cable is in the way if i route it where i thought it should go, which is under the steering column.  If i put them up over the steering column/pedal bracket, then they have too much of a bend in them.   :clueless: I am sure it is simple, but i can't figure it out. Help please  :1zhelp:
Re: How and where to locate the Temp. and Defrost/heat cables under the dash?
« Reply #1 on: September 02, 2011 - 08:31:15 PM »
I just looked & mine go up quickly to a hole in the brake bracket below where another brace or bracket attaches above.
Offline Chlngrcrzy
« Reply #2 on: September 02, 2011 - 09:09:17 PM »
Ok, that helps a lot. i noticed a couple holes in the bracket frame, just wasnt sure. i will give that a try tomorrow and see how they look. Thanks for looking at yours and getting back to me.   :2thumbs:
Offline Jamiez
  • Retro
« Reply #3 on: September 02, 2011 - 09:43:30 PM »
Maybe this will help...it's from the 74 service manual
