Author Topic: is my engine pinging???  (Read 1002 times)
Offline CUDA JAS
  • vroooooom!
« on: September 04, 2011 - 08:15:30 PM »
When I get on my 360, I can not get it rev over 4000 or so.
At wot the car just sort of falls over once i hits 4000.  It feels like it is running out of fuel.  When I let off on the pedal, the car picks back up.
I am concerned that this is engine ping...any thoughts.
Other than that the engine works well.
Jason
74 'cuda 360/727
Just call me a gearhead!
Offline Talkwrench
  • Perth, Western Australia
Re: is my engine pinging???
« Reply #1 on: September 04, 2011 - 08:23:19 PM »
Doing what your engine is doing you would be hearing it .. at WOT it comes on and sounds like ball bearings rattling in a can.
"Came too close to dying to stop living now!"
« Reply #2 on: September 04, 2011 - 08:55:09 PM »
That would be my first guess , a fuel restriction or lack of supply capability . pinging USUALLY happens at lower RPM & would not limit RPM . Pinging is similar to a tin can half full of marbles being shaken
« Reply #3 on: September 04, 2011 - 08:55:54 PM »
Fuel pump? Fuel line size?
Offline Skunkworks Challenger
  • Mopars forever!
« Reply #4 on: September 05, 2011 - 08:43:44 PM »
Yep, valve float or fuel starvation!  PK
The Brewmaster
Offline PlumCraZRT
« Reply #5 on: September 06, 2011 - 10:37:04 AM »
Sounds like a lack of fuel.  I've never heard of valve float at 4000 rpm...
mmmmm.... Mopar.... *drool*
Offline Cuda54
« Reply #6 on: September 06, 2011 - 12:00:55 PM »
Do you have a stock ignition or MSD? If MSD check to see if 4000 chip is in it. The chip would set the top end RPM.
Offline CUDA JAS
  • vroooooom!
« Reply #7 on: September 09, 2011 - 09:57:07 PM »
Thanks guys,
Sounds like he stock style fuel pump is not up to the task.
I am running a 3/8ths line from the tank to the pump.  5/16 from the pump to the carb.
Looks like I found another winter project.
Jason
74 'cuda 360/727
Offline 72cudamaan
« Reply #8 on: September 10, 2011 - 09:22:09 AM »
Jason, it may be a silly question, but... how is your float level?
If I cant fix it, it's broke
Andy  (phukker whither)
Offline CUDA JAS
  • vroooooom!
« Reply #9 on: September 10, 2011 - 01:04:48 PM »
I think that is great question.
the Primary is just under the sight hole.  The secondary is just a littel bit lower.
I have tried to bring them both up a little, but any more on the primary tends to mak the idle rich, and the secondary tends to leak out the bosters.
74 'cuda 360/727
